November 21, 2025, 06:41:56 AM *
Author Topic: wiring up handlebar mounted speakers 2003  (Read 1687 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: May 20, 2010, 06:17:40 AM »
I just got a set of Speakers and 2 radio shack volume booster things plus an XM antenna.  No name on the speakers but they are pretty big.   So if anyone has an Idea on how to hook them up I would appreciate any and all help on this.   Im not sure but I think after I hook it all up I need to get something from XM radio  not really sure.
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: May 20, 2010, 07:40:45 AM »
Here is what I did, to allow me to use my XM MyFi, on my bike...
Here is the xm MyFi...
http://www.google.com/products/catalog?hl=en&safe=active&resnum=0&q=xm+myfi&um=1&ie=UTF-8&cid=16320743016014594751&ei=b0j1S_fFAaTMNNfxnMYF&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CBcQ8wIwAg#
First, I have one of the original Hoppe fairings, that came with two speakers mounted in it.
Second, you will need an amp, to boost the volume (even if you have in line booster/volume controls, they probably will not be enough for making the music audible, at anything nearing cruising speeds), if you are using anything other than a real car or marine radio (say an iPod, XM, or some other MP3 player). This is what I got, and have it mounted under the seat, where the tool kit was...
http://www.uniqcycle.com/150-Watt-Mini-Motorcycle-Audio-Amplifier_p_30.html
Remember, many types of XM receivers made for home and car use, do not have volume controls.  Whatever your source, you want it to have a volume control.  After you set the amp, for the correct listening level, you can still control the volume, using the music source.
Third, you will need to run the music source through the amp, and run wires from the amp, to the speakers.
Sounds like a daunting task, but I use the XM MyFi, in the home dock, and love having my 'Deep Tracks' able to play in the house.  When heading out on a trip, I charge the batteries, put it in the handle bar cradle, and go rockin' on down the hiway...
Black Dog
Don't you know...
Garland
#618
Hendersonville NC
« Reply #2 on: May 20, 2010, 09:41:05 AM »
Black Dog, are you using the original speakers from the Hoppe fairing or change them out? I am going to be mounting one of these in a few weeks but have no idea of the quality of the speakers Hoppe used, and whether an upgrade is called for.
Black Dog
VRCC # 7111
« Reply #3 on: May 20, 2010, 10:17:54 AM »
PM sent...
Black Dog
Don't you know...
