January 31, 2026, 05:48:35 AM *
Author Topic: rotors  (Read 3175 times)
stormrider
Kinsey, AL
« on: May 20, 2010, 09:23:27 AM »
well, decided to buy new brake pads. not quite ready to be replace but did notice the rotors will need turning. so, who turns mc rotors. I may have to ship them to someone. no one around here will touch them. new oem are $$$$$$$$$$.
« Reply #1 on: May 20, 2010, 09:30:29 AM »
NO TURNING VALKYRIE ROTORS  Sorry Steve......just bring them to me and I will make stuff out of them........1800 Gold Wing rotors fit and are less $$
Garland
#618
Hendersonville NC
« Reply #2 on: May 20, 2010, 09:50:26 AM »
I just ordered some Gold Wing rotors and will be changing them out soon. Do you really have a use for the old rotors? You are welcome to my old ones if you will pay for shipping.
« Reply #3 on: May 20, 2010, 10:19:39 AM »
they don't need turning unless u were metal to metal and have deep groves. new oem pads or equivalent not organic will re-surface them and work fine. this is the same for the auto industry also, this is all a result of the new brake pad materials and designs.
Tropic traveler
Silver Springs, Florida
« Reply #4 on: May 20, 2010, 10:45:14 AM »
Yes GW rotors fit quite well! cooldude
Less than half the cost. Don't forget new retaining bolts.
'13 F6B red for Kim
« Reply #5 on: May 20, 2010, 11:21:17 AM »
EBC rotors here........
Love them.......
Also I use their pads.......
DO NOT use EBC pads on EOM rotors.....   Bad news for noise that bothers some of the riders.
« Reply #6 on: May 20, 2010, 11:37:41 AM »
Yes Garland....I will send you shipping if you send me the rotors and bolts if you didnt reuse them.....Ill pm my address
stormrider
Kinsey, AL
« Reply #7 on: May 20, 2010, 07:03:59 PM »
Thanks gentlemen. I took the new front and rim in to have the new tire installed today. Asked about turning rotors and the tire guy, Allen, told me pretty much the same thing. So, I'm happy. Got new pads the other day and will probably get another 5+ k miles on the ones on now. So I'll be good to go when needed.
« Reply #8 on: May 21, 2010, 05:37:58 AM »
I understand that GW rotors will fit the front, but the GW rotors are thinner than the stock Valkyrie rotors.
Tropic traveler
« Reply #9 on: May 21, 2010, 07:24:48 AM »
Valk front rotors -- 5mm new---- 4mm they are junk.
GL1800 front rotors -- 4.5mm new---- 3.5mm junk.
Same pads for both. I figure if Honda says they are good enough at 4.5 to 3.5 thickness range to stop a GW they are plenty good enough to stop a Valk.
Like saving the $$$ too!  cooldude  Cool
'13 F6B red for Kim
Mr.BubblesVRCCDS0008
« Reply #10 on: May 21, 2010, 05:38:12 PM »
I've been running the Goldwing rotors for over a year now and I'm very happy with them. cooldude
RP#62
Gilbert, AZ
« Reply #11 on: May 21, 2010, 05:56:29 PM »
Why couldn't you run the valk rotors to 3.5?
Just askin
-RP
Tropic traveler
« Reply #12 on: May 21, 2010, 06:00:35 PM »
 Grin Grin Grin
I probably did... & then some.
The stock rotors were SHOT at 100K!
That is a damn good question though.  ???
'13 F6B red for Kim
« Reply #13 on: May 22, 2010, 08:47:25 AM »
I think that is from the manual.
You know they have to stay within boundaries when promulgating standards.
The drop dead maximum limit is considerably greater.
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #14 on: May 22, 2010, 04:24:57 PM »
 YOU CAN TURN MOTORCYCLE ROTORS. A FRIEND OF MINE HAS A BUISNESS THAT DOES THIS. HE HAS TURNED ROTORS FOR ME. HE IS GOING TO BE A T INZANE ON FRIDAY AND SATURDAY WITH TURNED VALKYRIE ROTORS FOR YOU TO SEE. THERE JUST HAS TO BE ENOUGH MEAT ON THEM JUST LIKE YOUR CAR OR TRUCK.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
« Reply #15 on: May 23, 2010, 12:01:26 PM »
OK.......Ill rephrase......theres no way to turn a valkyrie rotor that is already worn, and make it smooth again AND still have it be within specs.  You only get .5mm on each side to work with and that includes the wear and the turning.  Lets just suppose you only used .25mm on each side due to wear.  you would be limited to removing .25mm with the lathe to have a "legal" rotor.  I know from experience....once you recognize the rotor to be worn, ridged, or in need of "turning"  Its considerably more than .25mm worn and it would take considerably more than removing .25mm to get it smooth.
Yes you can put any rotor on a lathe, doesnt mean you should
stormrider
Kinsey, AL
« Reply #16 on: May 25, 2010, 06:50:40 PM »
Hey Jeff, when I took the wheel in for the swap out, the mechanic said mine looked good, so no need to turn or replace. If and when they're shot, I want to put in an order for a Valk Rotor Lazy Susan.
« Reply #17 on: May 25, 2010, 07:48:19 PM »
Yea, how much?
« Reply #18 on: May 26, 2010, 04:19:00 AM »
LOL ok Steve...........  cooldude
« Reply #19 on: May 26, 2010, 04:26:00 AM »
Yea, how much?
Marty, I never really thought about selling these.........If I dont get the bolts with the rotors then each one costs me about $50 to put together...... no one has really asked to purchase these.....so I suppose I didnt think anyone would wanted to spend their chrome money .....LOL
I guess if you and steve start a tidal wave of interest here, I may be a busy dude eh?  Sounds like about the time many of the older bikes are needing their rotors replaced
CB1
DFW, TX
« Reply #20 on: May 26, 2010, 06:30:59 AM »
Any special year of GW? or will the current year work?
Thanks!
Chris
