January 31, 2026, 05:49:58 AM
In the middle of desmog....help!
Topic: In the middle of desmog....help! (Read 1990 times)
gcook1
Grand Rapids, MI
May 20, 2010, 12:52:44 PM »
I'm in the middle of desmogging...and I need a little clarification. I'm following QueXpress' instructions in the shoptalk area. But I'm confused on two things.
1. Block off the vents on the intakes for carbs 3 and 4 with 5/32 vacuum plugs. I'm looking at the picture in the instructions... looking at my bike... where are these vents??? I don't see what I'm supposed to plug.
2. Just to make sure I've got it straight... the 4 freeze plugs are for the air feeds to ports 1,2,5 and 6...right?
Thanks for any help. This is my first attempt at anything more complicated than an oil change. Scary, but fun!
Re: In the middle of desmog....help!
May 20, 2010, 12:56:15 PM »
What you are blocking off in the intakes is where vacuum lines used to be hooked to.....You no longer need vacuum lines so just plug the nipples on the intakes (base of intake facing in toward the center of the motor
Thunderbolt
Worthington Springs FL.
What Chris said
May 20, 2010, 04:26:17 PM »
and yes the plugs go in 1,2,5,6. I used 9/16" but you must already have those.
