January 31, 2026, 05:49:54 AM *
Author Topic: Sick Valk  (Read 2860 times)
The Real McCoy
« on: May 25, 2010, 01:04:24 PM »
I haven't had to ask for much help here the last 11 years (been very dependable) but I need some now. Pulled her (99 standard) out of the humid garage last night, warmed 'er up and noticed that she sounded weird, noisy motor and then backfiring if given any throttle , and then the cobra spotlights (installed per cobras instructions 10 years ago) went out. I began checking fuses and lookin' for anything out of the ordinary. No luck. Seems like the right side (1,3,5) is super weak (all I can hear is the left side working) I can pull all 3 plug wires off at the same time  with no noticable difference. I thought it was extremly weird that the spot lights went out at the same time also. I know this is very limited info, but thats all I really have right now. TIA
Daniel Meyer
The State of confusion.
« Reply #1 on: May 25, 2010, 01:17:42 PM »
I would guess low voltage/bad battery. Check it at the terminals/not running...should be at least 13v. Shouldn't drop below 12 with key/lights on.
CUAgain,
Daniel Meyer
The Real McCoy
« Reply #2 on: May 25, 2010, 01:50:05 PM »
Thanks for the quick reply. Checked the voltage, it's a little low=12.70. Charging now.
9Ball
« Reply #3 on: May 25, 2010, 02:05:50 PM »
12.7 V measured at the terminals is a good battery....100% charged.
http://www.yuasabatteries.com/faqs.php?action=1&id=30
I'd start looking elsewhere...while you're charging anyway.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Pete
« Reply #4 on: May 25, 2010, 02:27:48 PM »
Based upon your limited info. If 1,3,5 is not working the only thing in common is the gas line. Maybe that side is stopped up???? Check a carb bowl (1,3,5) to see if you have gas.
Mr.BubblesVRCCDS0008
« Reply #5 on: May 25, 2010, 04:22:25 PM »
How long has it been parked. Could something be blocking the airbox to that side? I had a car parked in a barn while I was in boot camp. I came back to a family of mice living in my air cleaner.
Cleaner Man
Grand Rapids, MI (actually Lowell- but who knows where that is)
« Reply #6 on: May 26, 2010, 03:45:51 AM »
I had the exact same situation last night...at first no gas in #1,3,5...none.  The bike sat for about 25 minutes while i was checking things out (I had just wired in running lights).  Tried to start it and she took right off.  It stalled on the road twice, and had no gas in any carb bowls.  Turned out to be an air lock in my quick-connect hose I have in my gas line.
« Reply #7 on: May 26, 2010, 04:16:49 AM »
Will do the same thing if theres not enough gas in the tank and its NOT on reserve when it needs to be.  The cobras light bar switch just "goes out"  very common, so the two symptoms arent necessarily connected  Grin
PS I wont laugh if it was a reserve thing (very hard)
The Real McCoy
« Reply #8 on: May 26, 2010, 06:19:08 AM »
Ha ha, you were right Chris. Thanks to all replies.
MP
North Dakota
« Reply #9 on: May 26, 2010, 08:45:46 AM »
I had to replace the Cobra light switch as well.
MP
"Ridin' with Cycho"
« Reply #10 on: May 26, 2010, 12:32:51 PM »
 Grin
ok, good...this is me NOT laughing really hard
 2funny
