January 31, 2026, 05:48:51 AM *
Author Topic: IS Trunk Bulb  (Read 2525 times)
NITRO
Eau Claire, WI
« on: May 27, 2010, 07:41:47 PM »
Does anyone know what size bulb I need for my IS trunk? The left brake light is out, but the running light is working fine.
When in doubt, ride.
MP
North Dakota
« Reply #1 on: May 28, 2010, 05:51:57 AM »
It is like an 1157, but has the flat, push in base.  Cannot remember the #.
MP
"Ridin' with Cycho"
cutter
Plantersville, Texas
« Reply #2 on: May 28, 2010, 06:12:57 AM »
Correct on the flat push in style, like the ones in your meter panel (dash) just larger. Had to do that a while back but can't remember the number either. Got'em at wally world
NITRO
Eau Claire, WI
« Reply #3 on: May 28, 2010, 07:13:45 AM »
As long as it's a pretty common bulb, I'm not too worried then. I'll switch it when we have the trunk apart to put on the guard bars. I guess I have to get it done before the VOAI ride-in now...
1FAST6
Sanford, NC
« Reply #4 on: May 28, 2010, 10:09:29 AM »
Everything you ever wanted to know about bulbs in the Valk!
http://www.rattlebars.com/valkfaq/schematics/rpage11.html
Sourdough
Tucson
« Reply #5 on: May 28, 2010, 10:26:56 AM »
Thanks for the link 1fast6.. I had one go out also and was waiting for an answer to Nitro's question.
01 I/S Black/Beige
97 Standard Bumblebee
NITRO
Eau Claire, WI
« Reply #6 on: May 28, 2010, 12:02:08 PM »
Wow, I hadn't seen this before. Thanks for passing it on.
sugerbear
wentzville mo
« Reply #7 on: May 28, 2010, 07:28:26 PM »
same here bookmarked that. splains everything i needed to know.
been wanting to put brighter tail/stops lights in my I/S cooldude cooldude
thanks
Oyeaa
« Reply #8 on: May 29, 2010, 03:43:36 PM »
 I recommend that you pull the original bulb out and take it with you.   I may be mistaken but my memory says the cross reference in the link is not accurate for the interstate rear bulbs.  I know I made a hand written note to myself what the correct bulb was for future reference but now I can not remember where I put the note!
Oyeaa
« Reply #9 on: May 29, 2010, 04:56:05 PM »
Can not find my notes, yet, but a little web search has me believing the brake/running light on the trunk of the interstate is a T6 Wedge Base #7443 dual element bulb.
1FAST6
Sanford, NC
« Reply #10 on: May 29, 2010, 08:58:56 PM »
I can't vouch for the accuracy of the list.  I replaced my tail lights with these (1.8"):
http://www.customdynamics.com/motorcycle_led_bulbs.htm#Genesis_LED_Clusters_
MP
North Dakota
« Reply #11 on: May 30, 2010, 03:03:45 AM »
1fast6:
Did you modify your sockets? The clusters here all use a round plug, while the socket on the trunk is flat.
Maybe I am looking at the wrong 1.8".   OEM comes in at a 90 deg. angle, and most LED's are made to be viewed straight on.  Or is it plug and play?
MP
« Last Edit: May 30, 2010, 03:05:22 AM by MP » Logged
"Ridin' with Cycho"
1FAST6
Sanford, NC
« Reply #12 on: May 30, 2010, 08:38:13 PM »
Yes, I did some modifications to get them in.  First I took the red lenses apart by heating with a blow dryer.  I lined the white housings with plastic pbags and filled them with "Great Stuff" expanding foam, like cupcake pans.  Next day I took a sharp knife and cut-off the tops of the "cupcakes" so they were flat.  I used hot glue to secure the LED Clusters to the flat tops of the foam "cupcakes and cut a slice in the foam to run the wires through and out the hole where the socket was.  Then I glued the lenses back on the housings and put it back together.  I soldered them in, using a Back-Off Wig-Wag brakelight flasher.  I wired them so the wig-wag would alternate inner and outer lights when I hit the brakes.  The clesters are VERY BRIGHT, and the flasher makes it almost impossible to miss the fact that I'm slowing down.
http://www.amazon.com/Signal-Dynamics-Back-Off-Wig/dp/B002OP6K2G
MP
North Dakota
« Reply #13 on: May 31, 2010, 04:16:03 AM »
Good info.  Thanks.
MP
"Ridin' with Cycho"
