March 16, 2026, 11:47:44 PM *
Author Topic: Electrical short on Chevy Tahoe  (Read 1831 times)
« on: May 28, 2010, 06:05:55 AM »
Back up lights come on when I brake.
Suggestions needed as to how I fix this. Please don't say remove back up bulbs.  Cheesy
« Reply #1 on: May 28, 2010, 06:11:58 AM »
What year Tahoe?  Did you add any lights or additional wiring?
« Reply #2 on: May 28, 2010, 06:20:13 AM »
1997 and no additional lighting.
JerryB
Takin' it easy!
Michigan
« Reply #3 on: May 28, 2010, 11:50:41 AM »
Have you had the tail light assys out for any reason?If not there is a connector inside the frame rail near the spare tire.Check and clean those pins and for a bad ground.......JerryB.
Retired and taking it easy!
« Reply #4 on: May 28, 2010, 11:57:38 AM »
Diito on what Jerry B said. Should be on the driverside.
the inspector
Buffalo NY
« Reply #5 on: May 28, 2010, 12:44:45 PM »
Britman....if this problem came on all of a sudden, with no input from you. As it sounds, I would look at either the switch for the back-up lights and or maybe the multifunction switch as sometimes it malfunctions and gets feedback (electrical current) and feeds a circuit that it is not supposed to feed. You also did not say if the the brake lights were working along side of the back-up lights? I would say the short would be in the switchs rather then any wires if you did not help it along with any input, BUT never rule out wireing as a last resort. Let me know what you find.....one more thing I beleive the neutral safety switch inside the transmission case may also be the problem, if my memory is correct, I think sometimes they short out from the heat and short together, you might check that also.
"the inspector"
"the inspector"
junior
new hampshire
« Reply #6 on: May 28, 2010, 03:20:31 PM »
its the circit bord in the tail light it was and is a common thing they get coroded and short out. most any auto parts store has replacements for them
Stanley Steamer
Athens, GA
« Reply #7 on: May 28, 2010, 03:27:26 PM »
Darn......I was thinking it was the Flux Capacitor gone bad!..... Wink Cheesy Grin
Stanley "Steamer"
"Ride Hard or Stay Home"
gregc
Media Pa.
« Reply #8 on: May 28, 2010, 05:10:49 PM »
  Remove the tail light, look and see if the bulbs are in their own socket, or if they are in a long multi bulb tray.  If they are in the long tray type arrangement, I would start there.  GM has had a problem with the multi bulb tray type sockets.
big turkey
« Reply #9 on: May 28, 2010, 07:39:42 PM »
Bad ground is a real good possibility, due to the amount of plastic on all of the new vehicles today.
But if not the GM dealer should help you out and probably save you money because they
know their stuff on thier stuff.
They may even have a recall on that item , look up your vehicle on NHTSA and should be there
if there is a recall. Google of course.
No matter how old the recall, if there is one, will be free.
Worth a try.
Big Al
Dogg
Berlin Md
« Reply #10 on: May 28, 2010, 10:46:39 PM »
jr hit it on the head. those things are junk. sometimes, you buy a new one from the parts store it dont work right either. get them at the dealer. I never had good luck with bulb trays from anyone else.
« Reply #11 on: May 30, 2010, 10:40:03 AM »
Just got back in from riding with the VRCC Memorial Day crew.
Got a polite written warning from the Roswell PD on Friday morning due to my back up lights coming on at the wrong time.
Both sides back up lights are coming on.
Have taken out the bulbs until Tuesday so I can use my truck wihtout getting stopped again.
Is the "tray" what the 3 bulbs fit into?
Never noticed before but shoudl my brake lights come on without the engine running and no key in ignition?
Michvalk
Remus, Mi
« Reply #12 on: May 30, 2010, 10:50:01 AM »
Brake lights come on weather key is on or not. Do you have a trailer hitch? Could be the light controller for your trailer lights shorting. Just a thought.
« Reply #13 on: May 30, 2010, 01:50:43 PM »
Uh Oh. Roll Eyes
I recently had to "rewire" the truck side of the hitch at the trailer connector. I'll go back and check my work.
Coot
« Reply #14 on: May 30, 2010, 09:23:42 PM »
You recently rewired for trailer hook-up.  Inspect the job; likely back-up lights wired into brake circuit accidentally.
Coot
