March 17, 2026, 08:00:42 AM
HELP - Need front brake lever to get home
Topic: HELP - Need front brake lever to get home (Read 1623 times)
humshark
Spring Hill Tennessee
May 28, 2010, 09:47:03 AM »
HELP!
I'm in Atlanta near Sandy Springs area. The parking arm knocked me off the bike on my way out and consequently home,....
Bike runs, is scraped up, and I have a broken front brake lever.
My left thumb hurts so riding without front brakes and a weak clutch is not going to cut it.
I need a lever BAD to get me home. I have an original at home.
Freewheeling (MOTORCYCLE shop in Douglasville ) has a lever - but they are a considerable distance from me....
99 Interstate
05 FJR
97 Vulcan '88' Hacked
humshark
Re: HELP - Need front brake lever to get home
May 28, 2010, 10:30:43 AM »
ok - heading up to Canton GA with rear brakes only. rested a bit - appears to be the closest thing thats on the way home - sort-of.
just got ot get the 30 miles there in one piece. talk to you-all later....
I'll gear up and have my phone on - but i may not be able to answer it directly.
four - one - four - 719 - forty - eighty. Just in case someone reads this and can intercept me. I'll be traveling S L O W.....
99 Interstate
05 FJR
mattfidaho
May 28, 2010, 10:40:37 AM »
good luck, sorry to hear about it :-( if you were in Idaho I would see what I could do
Psychotic Bovine
New Haven, Indianner
May 28, 2010, 11:48:20 AM »
is there enough left to clamp a small set of vice grips on it? Have heard people do this to get home (any autozone or hardware store should have a set of locking pliers). clamp them down tight on the "nub" and wrap a few wraps of tape or tie strap around it to keep it closes. Just my 2 cents.
"I aim to misbehave."
PAVALKER
Pittsburgh, Pa
May 28, 2010, 12:04:12 PM »
I got a stock brake and clutch lever... but no way to get it to you on your way home. Even UPS wouldn't be too timely this holiday weekend. You seem to be managing fairly well so far.... good luck.
John
9Ball
May 28, 2010, 01:46:43 PM »
try the Goldwing network...the brake levers for the 1500 are a direct fit..the clutch lever will fit if you hacksaw off the protrusion on the bottom.
Maybe someone here can provide a link or phone number
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
stormrider
Kinsey, AL
Reply #6 on:
May 28, 2010, 10:48:30 PM »
Don't know if you got the help needed. In the future try these guys. Network of bikers across the country. 800-4-bikers . I haven't personally had to use them but sounds like a great idea, similar to our Vortex.
humshark
Reply #7 on:
June 02, 2010, 11:03:11 PM »
UPDATE -
Found a shop 35 miles north - rode the distance carefully and made it fine. With a new "stock" lever in hand - I completed the trip home to the Nashville area.
* Note to those that have a lever brake at the pivot point....Yer brake lights are on! I figured it out after the cagers were riding up on my tail. I quick "feel" and i realized that the broken lever no longer placed any force on the brake switch - so they were on all the time until i got it replaced.
- AND FINALLY -
Bike is in the shop - completely taken by the cost to repair. They would have totaled this if I hadn't of worked a deal with Mark T for a new exhaust. Thanks again to the Horseapple Ranch!
-AND THANKS AGAIN to you out there. I figured it'd be hard to network out a fix last minute, but you never know. The fact that you guys are willing is worth it. ( And I do have a BAM motorcycle card in the wallet - just never thought of using it! )
The interstate will live.
99 Interstate
05 FJR
