January 31, 2026, 05:49:03 AM *
Author Topic: Are my carburetors the problem?  (Read 5586 times)
Art708
Jacksonville, FL
« on: May 28, 2010, 02:57:31 PM »
 My '98 Standard cranks up fine, idles well, runs through the gears well up to a point...then it starts missing..hesitating...not like it's misfiring but acting up. It will cruise on the highway effortlessly at 75-80 but if I open the throttle wide it just bogs and VERY slowly increases speed. If I ease on the throttle it will accelerate faster. I've never messed with a valk's carbs but I think someone needs to.
 Does this sound to y'all like the proper place to start?  Thanks in advance....
                   Art
Art
 2014 Kawasaki Concours 14
  Black
DFragn
« Reply #1 on: May 28, 2010, 03:10:52 PM »
It's possible there's a pinhole or small tear in one of the needle diaphragms. It's unusual, but I've seen it happen to a friends Valk with similar symptoms.
You might want to inspect them one by one with a bright back-light. Easy to get at, they're just under the primary carb covers.
Go easy they are delicate.
« Last Edit: May 28, 2010, 04:40:26 PM by DFragn » Logged
Daniel Meyer
The State of confusion.
« Reply #2 on: May 28, 2010, 03:50:29 PM »
Also check your petcock function and vent hose.
CUAgain,
Daniel Meyer
Art708
Jacksonville, FL
« Reply #3 on: May 28, 2010, 04:20:40 PM »
Petcock seems to be working fine....shuts off securely, reserve works. I'll check the vent tomorrow. Diaphragms can be accessed by removing the tops of the carbs, right?
Art
  Black
Larry
Northeastern BC, Canada
« Reply #4 on: May 28, 2010, 04:36:06 PM »
Was going to mention the vent line too and yes the chrome carb "caps" are correct as DFragn mentioned. Good luck.
DFragn
« Reply #5 on: May 28, 2010, 04:36:59 PM »
Yep, gentle on the screws. The chrome cover conceals the functional cover. Hold the covers in place as you remove the screws. The real cover contains the diaphragm/needle spring too. Not a lot of tension/push but don't damage it. Use one of the cover screws threaded into the center of the diaphragm to lift it and the needle out. Careful, the diaphragm may stick at the edges. Note how they're in there to replace properly and don't jab the needle when reinserting the diaphragm unit.
Art708
Jacksonville, FL
« Reply #6 on: May 28, 2010, 05:47:23 PM »
 Thanks a lot. If the vent check doesn't fix it then I'll check out the carb diaphragms. Wanna come over and supervise? Thanks again for taking time to help..
                    Art
Art
  Black
Mr.BubblesVRCCDS0008
« Reply #7 on: May 28, 2010, 05:49:05 PM »
I'ld open the tank cap with a spare key and run her down the road to make sure it's not a vent problem.
Wildman
« Reply #8 on: May 28, 2010, 06:23:42 PM »
Check the main fuel line for kinks.
« Reply #9 on: May 28, 2010, 06:35:18 PM »
that is the symptons of a lean condition. at those speeds and rpm, and no air box or jetting mods, then I would check, needle diaphragms as stated, air filter has a large hole in it or it is the intake manifolds leaking at the o-rings or the carb to manifold connectors.
Daniel Meyer
« Reply #10 on: May 28, 2010, 07:08:29 PM »
Pull a vacuum on the line to it and make sure it holds...
CUAgain,
Daniel Meyer
3W-lonerider
Shippensburg Pa
« Reply #11 on: May 28, 2010, 08:06:10 PM »
mine done the same identical thing a few years back when the diaphram in the petcock went bad..could get enough vacuum to keep fuel flowing on a regular basis but not enough fuel for wot.. i'd seriously dismantle the petcock and check that vacuum diaphram for a hole or slice.
MP
North Dakota
« Reply #12 on: May 29, 2010, 05:26:08 AM »
Do what Daniel suggests.  Take the vac line off #6, pull a vac with your mouth, stick your tongue on it.  Like a kid with a soda straw.  It should hold vacuum.  If not, diaphram is bad.
MP
"Ridin' with Cycho"
Art708
Jacksonville, FL
« Reply #13 on: May 29, 2010, 10:16:06 AM »
    Do I pull the vacuum with the petcock open or closed?  If it's open will that let a cylinder flood like a hydrolock? It'll be easy enough to hook up my MityVac and pull a small vacuum but I want to make sure to do it properly.
Art
  Black
« Reply #14 on: May 29, 2010, 10:44:19 AM »
the bowl floats will keep the needle and seat closed preventing a flooding condition. However do it with the petcock closed, ie double valve protection.
search my handle for petcock rebuilds and using a snubber in the vacuum line and the cause of hydro lock on the GL1500 goldwings when they first came out, honda's fix, and why on our bikes could be the same problem, the bowl vent hose. search also my post about seafoam and its ingredients and how they can cause hydro lock.
FLATSIX
Heist o/d Berg BELGIUM
« Reply #15 on: May 29, 2010, 01:31:36 PM »
In witch cuontry do you live Art?
Is it the USA-model or another Valkmodel that you have.
If it is an Australian or Europe model of Valk then I know that your problem is the vent-restrictorfoam on top of your airbox and I can help you - had the same problem last year.
US-models don't have that problem as their air is not restricted in the airbox.
standard '97 - european F6C - red & white - 27.000 KM
Art708
Jacksonville, FL
« Reply #16 on: May 29, 2010, 03:51:37 PM »
   USA, all the way.   cooldude
Art
  Black
Art708
Jacksonville, FL
« Reply #17 on: May 30, 2010, 08:57:36 AM »
 So this morning I opened the gas cap and took off at a great rate of speed. The bike ran pretty well up to 7K. Then after breakfast I left the tank cap locked and it still ran pretty well. I dunno...guess I'll just have to keep watch and the next time it happens I'll pop the tank cap and see if it clears up. Thanks for all the input guys....
                             Art
Art
  Black
« Reply #18 on: May 30, 2010, 11:59:15 AM »
                             Art
If what you do makes it good then the problem is a pinched vent line from the tank.
Usually happens when replacing the tank improperly.
MP
North Dakota
« Reply #19 on: May 30, 2010, 12:43:52 PM »
Carry a black wire tie.  Then, if it happens, stick it in the fuel opening, and close the cap.  That will allow venting thru the cap.  If that cures it, it is vent for sure.
MP
"Ridin' with Cycho"
