January 31, 2026, 05:48:49 AM *
Author Topic: Shocked - Amazed with Ragner exhaust mod...  (Read 2354 times)
DFragn
« on: May 28, 2010, 03:42:54 PM »
I was quite surprised with the results of doing the Ragner Cut to the OEM exhaust that I replaced my Viking exhaust with.
Not only does it sound better then the Viking pipes, I've got more power. And, it seems a little more power then the intact OEM pipes.
The OEM's were 100% intact until yesterday. All I did was the Ragner cut to the rear baffles, then 18" tips. I did not touch the front baffles.
I believe it's a better balance with a safe amount of back-pressure reduction. I have 38 slows [35's OE] with the pilots at 1.75 turns. It was running a bit rich at 1.75 prior to the "cut". Air intake seems to be increased [K&N with prefilter - existing] and it's running well, The cuts leaned the mixture perfectly, IMO. Oh, did I mention better sound then Viking's!!! Does it sound sweet when you get on it. Unlike the raspy Viking's. I was never quite happy with the Viking's even from new.
Edit:
I also went back to the OE needles.
Here's a vid after the "Cut".
Audio quality is TERRIBLE on my camera. It makes it sound tinny and there's the occasional "scratchy chirping". I think there's a small tear to the microphone.
I'll see about borrowing a camera to redo it for better sound reproduction.
Ragner.MP4powered by Aeva
« Last Edit: May 30, 2010, 12:19:34 AM by DFragn » Logged
shortleg
maryland
« Reply #1 on: May 28, 2010, 04:54:27 PM »
    Did you change the needles that came with the Vikeing pipes.
                   Shortleg[Dave]
Warlock
Magnolia, Ms
« Reply #2 on: May 28, 2010, 04:55:07 PM »
I have run Cobra exhaust, stock exhaust, glasspack mod. I got my best performance from the Ragnar cut and like the sound. I run the Ragnar on my 98 standard and glasspacks with silceners(sp) on my Tourer.
David
fstsix
« Reply #3 on: May 28, 2010, 05:00:19 PM »
I didn't care for the sound of the Vikings baffles, you must have picked back up your low end torque with the smaller Head Pipe, I reduced the size of my baffle in my Vikings with the (Samson Silver bullet) 2 1/4 inch, it sounds better and picked up some low end. Modified Vikings (R) Samson before wrapt with Packing (L) ...
« Last Edit: May 29, 2010, 04:53:36 AM by fstsix » Logged
valkyriemc
NE Florida
« Reply #4 on: May 28, 2010, 05:27:47 PM »
Good effort, sure would like to hear it with good mic...
Veteran USN '70-'76
DFragn
« Reply #5 on: May 28, 2010, 07:07:44 PM »
                   Shortleg[Dave]
Good point Dave,
I fergot to mention that.
I did go back to my OEM needles too!
« Last Edit: May 28, 2010, 07:13:16 PM by DFragn » Logged
