January 31, 2026, 09:02:02 AM *
Author Topic: timing belts  (Read 3689 times)
ricoman
Sarasota, FL
« on: May 30, 2010, 03:49:23 PM »
Thinking about replacing 12 yr. old belt (pre-emptive)
Chet's page shows NAPA, Gates, and Goodyear altenatives (although the Gates number seems to not exist).
Any thoughts-pro's/con's on these or stay Honda?
Mr.BubblesVRCCDS0008
« Reply #1 on: May 30, 2010, 04:08:50 PM »
I just did mine about two months ago I got the belts from NAPA store no problems what so ever.
valk2128
Suwanee, GA
« Reply #2 on: May 30, 2010, 04:11:06 PM »
+1 on Napa Belts
« Reply #3 on: May 30, 2010, 07:01:16 PM »
I just bought 2 Gates belts from O'Rielly's.   It will have a 'T' in front of the #.  The true # is T0275.   The 'T' stands for Timing.
ricoman
Sarasota, FL
« Reply #4 on: May 31, 2010, 01:37:00 AM »
Thanks all
Will get this done, it's on the to do list.
« Reply #5 on: May 31, 2010, 01:57:17 PM »
excessive underhood heat and sunlight shorten belt life.
a valkyrie has no underhood heat and sees no sunlight. honda only recommends inspection at 100k.
remember honda would warranty these bikes for 7 yrs, one could put 100k on in 4-5yrs.
EPA requires timing belts to last 100k in cars.
search out high mileage GL1500 goldwings and u will find most change belts at 100k. age has nothing to due with it.
YMMV and its your time and money.
ricoman
Sarasota, FL
« Reply #6 on: May 31, 2010, 02:59:58 PM »
Good point(s).
Maybe I'll put it off for a while.
Stude
« Reply #7 on: May 31, 2010, 03:23:41 PM »
 www.rockauto.com
Has Gates belts for the Valkyrie part # T275 and here is the best part I paid $17.55 each
Garland
#618
Hendersonville NC
« Reply #8 on: May 31, 2010, 04:01:43 PM »
www.rockauto.com
I can't seem to find these belts on that site, either through a part # search or by looking under the motorcycle part search. Can you give me a link directly to the T275 timing belts?
« Reply #9 on: May 31, 2010, 09:40:25 PM »
www.rockauto.com
Call them on their 800 #....   Work with a counter person.
Stude
« Reply #10 on: June 01, 2010, 05:37:50 AM »
 Call rock auto's 1 800 # talk to a person ... web site is a little flakey sometimes.
No place that I know of can beat that price.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #11 on: June 01, 2010, 06:21:12 AM »
When I got my IS I replaced the belts.  10-11 years and about 30K miles.  Several of the "teeth" were starting to peel off of the belt.  None had actually come off yet but the potential for disaster was there.  I would reccomend changing them because it is a pretty cheap fix.
blackvalk
PARK CITY, UTAH
« Reply #12 on: June 01, 2010, 07:52:22 AM »
I had the same questions a few weeks back. My mileage was low, but the bike is 12yrs old. I opted to change them. I bought two goodyear belts (duralast) from Auto-Zone that cost $23.00ea. The price on the post before mine was far less.
My belts looked good, but for $46.00 I felt better. While in there, I switched to a 4 degree Trigger Wheel. The bike gets up and goes now.
There was only one thing I will warn you about. On the crank shaft, there is a ring that has a mark on it. It aligns with an arrow to the right. When I touched the ring, it spun and wansn't connected to the crank. All I did was mark the tooth that aligned with the pointer so I was assured the crank was in the right position with the cam shafts. Rechecking the pointers was easy after tightening the idlers down.
Good luck!   Bill
Garland
#618
Hendersonville NC
« Reply #13 on: June 01, 2010, 08:05:00 AM »
www.rockauto.com
I just got off the phone with them. They are saying that they are currently out of stock.
blackvalk
PARK CITY, UTAH
« Reply #14 on: June 01, 2010, 11:41:50 AM »
Try Auto-Zone!
Old Geezer Richard
San Antonio , Tx
« Reply #15 on: June 01, 2010, 05:41:26 PM »
 Hey Ricoman , I had replaced my belts on my Valk when I had just bought her with about 53,000 just be on the safe side and will change them out again when she hits 100,000 miles its just cheap insurance ... I got my belts from NAPA just like Mr Bubbles did , can't go wrong with NAPA  cooldude
Garland
#618
Hendersonville NC
« Reply #16 on: June 02, 2010, 05:38:26 AM »
I tried ordering from NAPA about a month ago-they wanted about $80, and I would have to come back to pick them up. I thought I could order them online cheaper even with shipping.
