January 31, 2026, 05:48:46 AM *
Author Topic: Too much fork oil  (Read 2492 times)
Bald-dude
« on: May 31, 2010, 07:22:37 AM »
Will adding too much fork oil cause the front suspension to bee too stiff? tickedoff
DFragn
« Reply #1 on: May 31, 2010, 07:27:01 AM »
Why are you considering this? If it's about a soft condition replace the springs. Trying to do it with fluid could blow a seal.
YES, adding beyond OE spec's will reduce the air space in the tubes.
Remember that... air compresses - fluid does not.
« Last Edit: May 31, 2010, 07:29:19 AM by DFragn » Logged
Bald-dude
« Reply #2 on: May 31, 2010, 07:52:45 AM »
I had my seals replaced at the dealer and it just feels stiff.  Might just be me.
DFragn
« Reply #3 on: May 31, 2010, 09:03:30 AM »
It's possible the dealer screwed up [too much] but unlikely. Give it some time and see how it feels out for you.
A couple of extra ounces [beyond spec] would make a difference [harder].
Were the seals leaking? If so, loosing just an ounce would make it softer. That could be the different feel you sense and became accustomed to.
« Last Edit: May 31, 2010, 09:05:42 AM by DFragn » Logged
« Reply #4 on: May 31, 2010, 09:56:38 AM »
The dealer might also have used a heavier oil, but generally a slight excess will do as DF said. And true...yours may have been low and you got used to it being a bit soft.
asfltdncr
« Reply #5 on: May 31, 2010, 02:31:32 PM »
And....Lead to seal failure.  Make sure you don't have too much oil.
