January 31, 2026, 05:48:45 AM *
Author Topic: dumb question  (Read 1769 times)
« on: May 31, 2010, 09:39:43 AM »
I was taking out the amsoil air cleaner (like the K&N- spray with oil after cleaning)
and in the process of taking off the hoses from the petcock (thanks joe in STLOUIS for the flat screwdriver tip) I noticed that there was a clamp on the fat hose- which I dropped onto the  ground using said flat screwdriver Wink and found this morning but that there was no clamp on the tiny hose next to it
Does that hose need a clamp and what exactly is that one attached to on the other end  #6 carb? If my rememberer is working that is the vacuum hose yes?
Not riding today anyway  fixed the pool and I am gonna be in the water till the heat of the day passes me by
Oss cooldude
junior
new hampshire
« Reply #1 on: May 31, 2010, 10:02:15 AM »
that little hose is what operates the vacum on the coverset of the petcock. before i had changed over to the pingle mine had a spring clamp on it
« Reply #2 on: May 31, 2010, 04:01:57 PM »
got it off and on ok,  runs great  Now I am good for another year or so.
far as I can remember that little hose never did have a clamp coolsmiley
