January 31, 2026, 07:32:17 AM
Final Drive oil change and drive shaft questions
Topic: Final Drive oil change and drive shaft questions (Read 2067 times)
dennis_obryan1965@msn.com
May 31, 2010, 10:51:10 AM »
I have removed my final drive shaft. I am now ready to clean and reinstal everything but I have a couple of concerns.
1. on the end of the drive shaft that goes into the "punkin" there is a metal ring that goes around and sets down into the drive shaft splines. I noticed a 1/4 in. gap in the ring. Is this normal or is something broken?
2. I found Final drive oil inside the housing that the drive shaft slids into on the final drive. This is after it has set for a couple of days. Is this okay?
3. Also on this same shaft that the final drive slides into I rotated the shaft around to make sure everything felt okay and smoth, and it seems to be okay, but if I twist it back and forth real fast I fill some play and notice a clicking sound. Is this okay?
4. I Changed the final drive oil (Blue Ray 80/90 it was red in color) book calls for 80 is 80/90 okay?
Thank you for your time and please excuse my ignorance of mechanics and lack of knowledge of proper names for parts.
Any advice is greatly appreciated
Re:Sorry: This is a 97 Tour, Final Drive oil change and drive shaft questions
May 31, 2010, 10:54:00 AM »
Forgot to add the year and model to origonal post.
Re:97 Tour: Final Drive oil change and drive shaft questions
May 31, 2010, 11:05:09 AM »
Sorry, 97 Tour 76000 miles
Re: Final Drive oil change and drive shaft questions
May 31, 2010, 11:06:02 AM »
Sorry: 97 Tour
May 31, 2010, 11:15:18 AM »
The descriptions of the parts all sounds normal to me. Make sure you put a little moly grease on each end of the driveshaft. The oil you put in the final drive. Was it hypoid gear oil? I believe it will carry the API GL-5 rating if it is. It should say "hypoid" gear oil
I hope you have a Honda book for the proper sequence for re-installation.....if not search the shop talk and this tech board the procedure is there many times. IT MATTERS
May 31, 2010, 11:58:42 AM »
Thank You
It is Hypod and i do have a book and will tourqe the axcel nut before I tighten the final drive unit.
