January 31, 2026, 05:48:44 AM *
Author Topic: Final Drive "Punkin" Sleeve moves.  (Read 1731 times)
dennis_obryan1965@msn.com
« on: May 31, 2010, 01:03:24 PM »
While inspecting my 97 Tour final drive punkin I notice the sleeve that goes threw the center of the punkin was cocked sideways to about the 2 oclock position. I took a screw driver and was able to move it back to the center position. It this sleeve suppose to move like this or do I have a problem. The punkin is off the bike.
I have had a lot of left rear bearing problems on this bike and wonder if that could be cause of my problems.
« Reply #1 on: May 31, 2010, 01:31:51 PM »
It moves, no problem.
Daniel Meyer
The State of confusion.
« Reply #2 on: May 31, 2010, 05:19:16 PM »
That's normal. It's only slipped in there and held with an oil seal.
Follow the proper assembly order (tighten the 4 nuts that hold the pumpkin on last--after the axle is torqueud) and everything will line itself up correctly.
CUAgain,
Daniel Meyer
