January 31, 2026, 09:01:44 AM *
Author Topic: Battery Dehydrates  (Read 2039 times)
Jesh
New Jersey
« on: May 31, 2010, 02:59:49 PM »
Anybody know what causes battery to dehydrate?
Brad
Reno, Nevada
« Reply #1 on: May 31, 2010, 03:08:24 PM »
If you mean loosing water, usually overcharging.
Jesh
New Jersey
« Reply #2 on: May 31, 2010, 03:42:47 PM »
Thanks Brad,but what would cause it to overcharge?
upjeeper
« Reply #3 on: May 31, 2010, 05:51:01 PM »
could be a problem with your alternator, putting too much charge in. regulator burned out maybe?
or if the battery is really dehydrating you could have a crack in the battery case itself
sugerbear
wentzville mo
« Reply #4 on: May 31, 2010, 08:04:58 PM »
anything over 15.5 volts with the motor running  1000-2000 rpm is overcharging the battery.
manual says check at 5000 rpm WTH
« Last Edit: May 31, 2010, 08:07:02 PM by sugerbear » Logged
« Reply #5 on: May 31, 2010, 10:19:47 PM »
Anything over 14.5 is high and a bad battery that is sulfated will also cause problems.
Dennis Klinefelt
« Reply #6 on: June 01, 2010, 03:31:15 AM »
as far as i know either gel or AGM batteries are used in three Valk ...i.e.no liquid..
sugerbear
wentzville mo
« Reply #7 on: June 01, 2010, 08:11:21 AM »
"With the headlight Hi beam on, restart the engine.
Measure the voltage on the multimeter when the engine runs
at 5,000 rprn.
STANDARD :
Measured battery voltage (page 16-51 <Measured charging
voltage (see above) (<15.5 V at 5,000 rprn"
page 16-7 honda valkyrie manual also page 16-3
look it up
« Last Edit: June 01, 2010, 08:13:34 AM by sugerbear » Logged
Jesh
New Jersey
« Reply #8 on: June 01, 2010, 02:39:43 PM »
Thanks for the help. This was a problem my brother was having on his V Star 1100. After replacing the battery with a new one from Walmart he still had the problem but he`s working on it. Thanks again!
« Reply #9 on: June 01, 2010, 05:14:15 PM »
at 5,000 rprn.
STANDARD :
look it up
You are right, Shocked  but its still to high,  Grin  batteries fully charged at ;12.3 volts dont like to be charged at 15.5 they will die a early death  Cry
