January 31, 2026, 09:01:50 AM *
Author Topic: Carb jet question  (Read 2032 times)
scooter
Minnesota
« on: June 02, 2010, 06:33:20 AM »
I bought a 97 Valk with Cobra sis by six's on it.  The guy I bought it from "thought" the previous owner put a Cobra jet kit in also, but wasn't sure.  I just put the stock exhaust back on.  My question is,  Is there any way to tell if there IS a jet kit in the carbs without taking it apart?  Is it good to run a jet kit with stock pipes?  It seems to start a little harder than it should and smells a little gassy when warming it up in the morning.  Thanks.
97 Valkyrie standard
scooter
Minnesota
« Reply #1 on: June 11, 2010, 08:09:03 PM »
Help Please.  Does anybody have any advise?  Thanks.
wizard -vrccds#125
Hitchcock Tx.
« Reply #2 on: June 11, 2010, 09:07:42 PM »
Cobra kit is only springs and adjustable needles. should be no problem.
fstsix
« Reply #3 on: June 12, 2010, 04:15:10 AM »
These bikes come from the factory Jetted Lean, if it did have Needle or jet change that would be a plus, But how is Gas millage, The only way to really know is to inspect, but if it is jetted that just means your bike Cylinder temps will be cooler.
« Reply #4 on: June 12, 2010, 05:34:00 AM »
the cobra exhaust jet kit consisted only of new richer needles and slide springs. the main jets are not part of the kit and most likely where never changed $$$.  the cobra needles are adjustable. just pull them out, see shop talk and raise the clip one notch, 2 notches I believe will be too lean. the kit I tend to remember sets the clip at #3 position. move it higher and turn your idle mixture screws close 1/2 a turn. see how she runs.
or just get a set of oem needles, somebody should have a set for sale in the classifieds.
go to the tech section of factorypro.com great info on how to tune the three circuits of cv carbs.
9Ball
« Reply #5 on: June 12, 2010, 06:58:40 AM »
+1 what CAEC said...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
scooter
Minnesota
« Reply #6 on: June 12, 2010, 02:01:28 PM »
Thank you very much everyone!!
