March 17, 2026, 01:24:04 AM *
Author Topic: air port sercurity  (Read 1335 times)
john
tyler texas
« on: June 02, 2010, 02:57:34 PM »
The airport security solution:         cooldude
Here's a solution to all the controversy over full-body scanners at the airports.
Have a booth that you can step into that will not X-ray you, but will detonate any explosive device you may have on you.
It would be a win-win for everyone, and there would be none of this crap about racial profiling, and this method would eliminate a long and expensive trial.  Justice would be quick and swift.  Case closed!
This is so simple that it's brilliant.  I can see it now: you're in the airport terminal and you hear a muffled explosion.
Shortly thereafter an announcement comes over the PA system, "Attention standby passengers, we now have a seat available on flight number..."
Works for me!         coolsmiley
vrcc # 19002
Lonerbtw
Porterville Cal.
« Reply #1 on: June 02, 2010, 03:10:39 PM »
  Think about it. Put a small pot belly pig on each plane and let it run loose. Kids have something to enteraine them  and no boom factor.
  Loner cooldude
ricoman
Sarasota, FL
« Reply #2 on: June 02, 2010, 03:47:40 PM »
great idea!
Pete
« Reply #3 on: June 02, 2010, 04:49:28 PM »
Bullet proof the pilot bulkhead and issue all passengers there choice of pistol (bullets lubed with pig fat) and knife (greased the same way). And do away with all security.
alph
Eau Claire, WI.
« Reply #4 on: June 02, 2010, 05:18:04 PM »
instead of serving peanuts or pretzels, make it pork rinds and bacon bits!!  also have the infidel flight attendents wear nothing but string bikini's!!
