January 31, 2026, 09:02:04 AM
Difference between Valk Gas Tanks
Topic: Difference between Valk Gas Tanks (Read 2557 times)
rmrc51
Palmyra, Virginia
March 18, 2009, 10:44:13 AM »
Here's another newbie question for you vets out there.
What is the difference in capacity and specs between the Standard, Tourer and Interstate gas tanks?
I have a standard and would like to eventually put an Interstate tank on not only for the supposed increase in fuel but also for the fuel gauge option.
VRCC # 30041
BigMac (SoCal)
Moreno Valley, California
Re: Difference between Valk Gas Tanks
March 18, 2009, 10:59:14 AM »
The Standard tank is 5.3 gallons where the Interstate tank is 6.9 gallons. It's one of the best improvements you can do.
Dave
rmrc51
Palmyra, Virginia
March 18, 2009, 11:10:06 AM »
Is there any issue regarding proper fit with the front seat on my standard? ???
VRCC # 30041
christlj
March 18, 2009, 11:48:42 AM »
Your standard seat will fit...it is just a little more snug than with a standard tank.
March 18, 2009, 12:11:52 PM »
Your seat will fit but you can do a "Nose Job" on your seat. It involves removing the vinyl and cutting off some foam. Also, the I/S tank has a fuel guage so a sending unit is on the bottom of the I/S tank. You can block the hole or install a sending unit. Motosens makes a fuel guage which can be used on a standard when mounted on the handlebar.
June 01, 2010, 08:51:35 PM »
Quote from: BigMac (SoCal) on March 18, 2009, 10:59:14 AM
Dave
So, where would one come up with a I/S tank? Cost?
blackrams
Reply #6 on:
June 01, 2010, 10:24:16 PM »
Evil-Bay - EXPENSIVE........
Anthony
Belgium
Reply #7 on:
June 02, 2010, 01:21:08 AM »
they look similar, but the IS version is a bit wider and higher in the front, and is higher where the seat touches.
mounting is the same.
you will need to shim the IS tank if you have stacks on your carbs.
Anthony
Reply #8 on:
June 02, 2010, 04:21:48 AM »
Hmmm, well I guess I'll have to start looking for one. Thanks.
blackrams
Misfit
Colorado Springs Colorado
Reply #9 on:
June 02, 2010, 06:29:29 AM »
Quote from: blackrams on June 01, 2010, 08:51:35 PM
Dave
blackrams
Check this out
http://www.rmworksinc.com/
and Roger is a VRCC supporter.
