January 31, 2026, 07:32:58 AM *
Author Topic: anyone else have problems with Amsoil  (Read 3145 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« on: June 05, 2010, 08:30:37 PM »
last wensday i changed to amsoil 10w40
thursday i rode about 40 miles to town and back and 5 miles before i got home the valk backfired real loud out the left side under hard acceleration, i didnt think much of it and went home and parked it
friday morning about 150 miles down the road a valve started clattering, i ended up with 1400 miles on it before i got home
i have been determined to prove its not the oil, so today i adjusted all the valves and changed the exhaust gaskets
#4 and #6  exhaust valves on the left side where i hear the noise was very loose
but nothing has helped so tomorrow i am changing back to lucas  tickedoff
blackcat
« Last Edit: June 05, 2010, 09:01:05 PM by blackcat » Logged
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
« Reply #1 on: June 06, 2010, 04:45:53 AM »
Well, let us know.  My guess is that it has nothing to do with the oil at all.  If two valves suddenly got loose, Id check the torque and gap on all of of them.  The way I remember it....Loose means they are not opening as much which means they can burn......if that happened no oil is gonna fix it, but yet oil doesnt cause valves to loosen....
Kap
Oxford, MA
« Reply #2 on: June 06, 2010, 05:04:21 AM »
Sorry to hear about your problem. The only thing I'm sure about is it's not the oil just a bad coincidence. You might want to check out other things while your at it. It's always good to maintain your vehicle.
valkyriemc
NE Florida
« Reply #3 on: June 06, 2010, 05:27:55 AM »
Nevr heard of heard of that - ever.
Veteran USN '70-'76
« Reply #4 on: June 06, 2010, 05:29:03 AM »
I've been using Amsoil for years both in the engines and in the final drives. Helps the final drive run cooler for one thing. Be sure you're positioning the crank correctly when checking/adjusting the valves. I like to do it with the plugs pulled, you're not fighting the compression when turning the crank.
fstsix
« Reply #5 on: June 06, 2010, 05:40:05 AM »
Have you done the desmog? them Pair valves can really makes some noise, Do you have a Dyna 3000? they will act up time to time and will Backfire.
« Last Edit: June 06, 2010, 05:41:49 AM by fstsix » Logged
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« Reply #6 on: June 06, 2010, 05:54:28 AM »
I recently changed to Amsoil motorcycle which is 20w-50.  After I road it a couple of hundred miles I noticed what I thought was a chatter as well.  The more I road though I noticed it was not the valves but the pair valves themselves.
Amsoil made my engine run so much smoother after the crud had come off of everything that all I could hear was the engine whine and pair valves.
I am closing on 1000 miles on the oil change and plan on changing it again just to get the crud out that the Amsoil released.
BTW, I plan on doing the pair valve removal process after RedEye gets his Chrome kit ready for sale.
VRCC #29625
'98 Tourer
Farther
Quimper Peninsula, WA
« Reply #7 on: June 06, 2010, 07:25:32 AM »
 Do you have any details or a link for this?
~Farther
SgtBunny
Kingwood, WV
« Reply #8 on: June 06, 2010, 07:49:19 AM »
Not trying to hijack the link, just passing the requested info.
http://sites.google.com/site/valkparts/
VRCC #29625
'98 Tourer
Pete
« Reply #9 on: June 06, 2010, 08:04:20 AM »
Very strange!
Did you change from a heavier weight oil?  Like 20w50, lighter oils will sometimes allow sounds to seem louder and be louder.
How far out were the valves?
If your issues were/are oil related (quality related) your symptoms would indicate rapid wear in the valve train and possible lack of lubrication. It is hard to believe that any decent quality oil would cause that unless something was very wrong..... ( I have no experience with Amsoil, so I cannot speak directly to there quality)
You might want to send in a sample of the oil from the engine to an oil analysis lab, if you think that is the issue. And do an oil/filter change back to the original oil you were using, NOW.
valkyriemc
NE Florida
« Reply #10 on: June 06, 2010, 12:27:01 PM »
Very strange!
Easy to find out:http://www.enhancedsyntheticoil.com/New_Motorcycle_Oils.htm
Veteran USN '70-'76
blackcat
Mounds, Arkansas
« Reply #11 on: June 06, 2010, 03:44:20 PM »
it has been desmoged
all i did was chance from lucas 10w40 to amsoil 10w40
#6 exhaust valve was out to .014 the rest were just barely out of adjusment
the thing i cant figure out is that this noise started almost instantly the next morning
fstsix
« Reply #12 on: June 06, 2010, 04:25:46 PM »
Just re read the post, i had exhaust nut at the head-pipe loose on left side last week, sounded like valve Tappet, got it hot and very carefully cranked it down, no more valve Noise, tight valve will burn a valve, loose will help prevent Float, i run all mine looser than factory spec's , too tight will keep valve from closing all the way and burn a valve, safer loose.
Pete
« Reply #13 on: June 06, 2010, 04:49:52 PM »
Did you mean .014 or .0014????
.0014 is not that much. Matter of fact it would not make that much noise if just .0014 out.
Did the adjustment actually make a difference in the noise?
.014 different story - something has happened! Was the adj nut loose??
I wonder if the night before you had carbon-ed up an exhaust valve causing the backfire.
A carbon-ed exhaust valve will make a noise and then stop and start again later.
It will come and go at odd times.
Carbon on the valve stem is the what causes it to stick and release.
Also wonder if the backfire was on 6 and caused a seating problem after??
« Last Edit: June 06, 2010, 05:21:19 PM by Pete » Logged
« Reply #14 on: June 06, 2010, 05:32:36 PM »
I would put air in the cylinders with the valves closed or a leak down test. I would also check the cam timing just a thought. A compression test would not be the best choice here. I doubt oil has anything to do with the problem, I would be more suspect of the filter if I was going that route.
« Last Edit: June 06, 2010, 05:34:27 PM by Robert » Logged
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #15 on: June 07, 2010, 05:27:14 AM »
Possible take the filter apart and check for debris??
Dress for the slide, not the ride. ATGATT
VRCC #2505
dragonslayer
palm bay fl.
« Reply #16 on: June 07, 2010, 07:21:59 AM »
You didn't say what type of filter you used but if I remember right???? there where some problems with the Amsoil filters a while back.Been awhile but who knows if is old stock or a new problem.I believe the internals where collapsing causing oil starvation.Like I said been awhile so you moght want to check archives.
2k IS
98 Tour
2001 Stand
valkyriemc
NE Florida
« Reply #17 on: June 07, 2010, 04:50:37 PM »
Like this ??
http://www.valkyrieforum.com/forum/tech_archive.cgi?read=847018
« Last Edit: June 07, 2010, 06:21:35 PM by valkyriemc » Logged
Veteran USN '70-'76
