January 31, 2026, 07:32:55 AM *
Author Topic: H E L P . . . Need Interstate Fog light Fuse location.  (Read 2062 times)
nors
« on: June 07, 2010, 09:45:34 AM »
H E L P . .  .Fog lights(Driving Lights) don't work in the used Valk I bought a few days ago and can't read the top diagram on the fuse box on the right side (if that's where the fuse is for the fog lights?).
Diagram not in owners manual. Fairing is stock.
My Cymer manual won't be here for several more days, can anyone tell me where the Interstate fog light fuse is located and the amps?  or where there is a diagram of the fuses online?
« Last Edit: June 07, 2010, 10:02:02 AM by nors » Logged
MP
North Dakota
« Reply #1 on: June 07, 2010, 11:36:48 AM »
The fog lights are option.  May be wired differently.  Mine have an inline glass fuse under the RH side cover, yours may differ!
MP
"Ridin' with Cycho"
1fastbob
South Central Kansas
« Reply #2 on: June 07, 2010, 03:59:08 PM »
I am reading from a copy of the Honda Interstate fog light installation instructions....
"Replacing the fuse
1. Remove the right side cover.
2. Find the fuse holder taped to the fog light harness located near the fog light power relay.
3. Remove the vinyl tape to free the fuse case from the fog light harness and replace the fuse with a new one.
4. Reinstall the fuse case and the right side cover in the reverse order of removal."
Looks like the relay would be wire tied to the main harness under the right side cover if the installer followed instructions.  I do have a brand new wiring harness that is currently not installed if you need a picture of it.  According to the manual it should be a 10 amp fuse.
Hope this helps.
Bob
I'm on somebody's list! BFD!
nors
« Reply #3 on: June 08, 2010, 09:24:14 AM »
THAT'S a big Help!  Could not of asked for more.
