January 31, 2026, 09:02:37 AM *
Author Topic: Trailer 4 bike 5 plgs  (Read 2613 times)
Kendall
Arizona or on the road
« on: June 07, 2010, 08:18:06 PM »
Ok i just got a pull behind trailer and it has a 4 flat plug, my Interstate has a 5 flat plug. Couple folks told me i just need a 4 to 5 adapter plug but after 8 parts stores im not having any luck. Tried wiring and i can get ground, right and left turn. However i cant get run and brake together, just one or the other. So what do i need???? Any idea where to get a adpter plug ?   ...... Thanks Kendall
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: June 07, 2010, 08:40:42 PM »
  If your old trailer had separate brake, running and turn lights, you're more likely than not going to have to get a 5wire to 4 wire  tail light converter. Something like these http://www.wiringproducts.com/contents/en-us/d141.html
Do you have an electrical connections relay isolation package? If yes, they do make a a 5-4 adapter that works great.
If you do a search for taillight converter you should find some more hits.
hope this helps you
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #2 on: June 07, 2010, 08:51:41 PM »
Have you tried a u-haul store for an adapter? I also find them often in tractor supply stores and harbor freight.
good luck
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
« Reply #3 on: June 07, 2010, 10:19:02 PM »
Kendall, go find a 5 pin plug and rewire it.......  Less headache in the long run.
I tried that convertor thing a few years back and had nothing but trouble.
Finally about 6 months before I sold it, I rewired it and the gremlin went away.
« Reply #4 on: June 08, 2010, 07:35:36 AM »
Kendall: Go to Pep Boys and get a Hoppy's trailer adapter. Part # 46255. It's a powered converter and converts the bike from 5 to 4 wires and correctly fires the trailer lights. I have it on both the Valk and Wing for my tent trailer.
Kendall
« Reply #5 on: June 09, 2010, 09:11:31 PM »
Thanks Everyone!    Think ill try PepBoys or Uhaul. RJ rewiring would prolly work better but i dont wire too well, so ill cross my fingers and hope for luck. Thanks Everyone..
Craig N. AZ
Gilbert, AZ
« Reply #6 on: June 10, 2010, 10:12:23 AM »
Kendall… I just put on the tail light converter on my bike and a 5-wire round connector. The best price I found was at Amazon.com.
I also took it out for a test pull last weekend and something fried my 6mo old battery.
Amazon.com   Hopkins 46255 Power Taillight Converter   $38.59
Etrailer.com  for the plug
Ben
Abilene TX
« Reply #7 on: June 10, 2010, 01:58:36 PM »
I use an extra single connector with the 4 pin,(grounded wire to trailor and bike)
Then 1. Left turn
        2. right turn
        3. Brakes
        4. runing lights
works like a charm...  39cents
Kendall
« Reply #8 on: June 10, 2010, 07:58:21 PM »
Craig did you figured whatfried the battery?  Des just surprized me and brought home the convertor
Craig N. AZ
Gilbert, AZ
« Reply #9 on: June 10, 2010, 09:33:37 PM »
Kendall….. I was just heading out to the garage now that it’s cooled down below 90deg, to put the new battery in and see if any of the trailer wiring look bad. I’ll keep you posted if I find anything. Do you need any help wiring your bike????? Let me know.
Baloo
Rimouski, Canada
« Reply #10 on: June 11, 2010, 06:55:19 AM »
I did install a converter on mine (99 IS) many years ago and never had a problem with it.
Never ride any faster than your guardian angel can fly...
Kendall
« Reply #11 on: June 12, 2010, 02:39:13 PM »
Thanks Craig apreciate the update and offer, i havent looked at it yet .  But if i need help ill holler. Thanks Kendall
Craig N. AZ
Gilbert, AZ
« Reply #12 on: June 12, 2010, 10:55:48 PM »
Looks like my problem is a combo bad battery and bad Hoppys. Took the battery back and it was bad.  I had them test the new one and it was bad too. I got a better battery but it’s about 1/2in taller. The trailer tested good but when I tested the Hoppys, all pins tested with 12+ volts with only the key on. I bought it thru Amazon.com so now I need to see if they will warranty it. It’s always something.  Angry
Kendall
« Reply #13 on: June 13, 2010, 12:03:42 PM »
Thanks for letting me know... Sounds like you had a run of bad luck..
