January 31, 2026, 09:01:56 AM *
Author Topic: J&M Speakers  (Read 2262 times)
cef2lion
Central PA
« on: June 09, 2010, 07:31:15 AM »
I need a set of front IS speakers. I found an old thread about using J&M replacement speakers for the Wing. But two part numbers were mentioned. Which is correct for the Valkyrie front fairing? I know the speakers are 4.5 inches. The J&M site doesn't list the size or depth. They are both rated at 3 ohms.
RSPAGL18 or RSPF-GL15
cef2lion
Central PA
« Reply #1 on: June 09, 2010, 08:13:35 AM »
J&M responded to my inquiry.
You would want the RSPF-GL15 for the Valkyrie.
J&M Corporation
1415 South Cherry Avenue
Tucson Arizona 85713-1997
Mr.BubblesVRCCDS0008
« Reply #2 on: June 09, 2010, 03:23:29 PM »
I got mine from HDL they have both the 4.5 in for the front and the 4 in for the rear. Great improvement over the old stock speakers. About  $128 total shippinng and all. You can also go to wingstuff.com and look under 1500 goldwings for the rear and 1800 for the front.
« Reply #3 on: June 09, 2010, 03:28:23 PM »
I have the boxes mine came in but thery are at home and I won't get back there until 5 am.
« Reply #4 on: June 10, 2010, 07:32:36 AM »
Not sure if these are a direct fit, but a guy on the Gold Wing board raved about these.
http://www.metrixaudio.com/Home.html
BradValk48237
Oak Park, MI
« Reply #5 on: June 10, 2010, 02:05:56 PM »
If you look on some of the old posts here you will see a thread about using the Polk audio speakers from Crutchfield....  I did the mod myself and I think it was around $120 to do all 4 on my I/S.
Someone might know where to find the install guide.
B
« Reply #6 on: June 12, 2010, 08:38:21 AM »
Finally got back on the board and at home to boot. The ones I used were USK-9000 for the rear and RSPA-GL18 for the front. Direct replacement about an hour for all four, much ,much better than stock
cef2lion
Central PA
« Reply #7 on: June 13, 2010, 04:57:25 AM »
Thanks. J&M has a set in the mail to me.
Jack B
Two Rivers Wis
« Reply #8 on: June 13, 2010, 05:13:34 AM »
I have a set of front speakers from big bike parts they are a direct fit I'd sell for $40
Let’s RIDE
