March 17, 2026, 07:58:28 AM *
Author Topic: Dead Battery??????  (Read 1801 times)
Slick
Jupiter, Florida
« on: June 10, 2010, 02:44:09 PM »
I started the beast to get it out of the garage, so that I could get up into my attic. Well lo and behold went to restart her and it cranked but no start. I noticed that I was low on fuel so I flipped her into reserve with same result.
I also noticed that my trip odometers reset at zero. Well after a few more attemps, you guessed it I just got alot of clatter.
Any thoughts oh great Valk owners? Battery, or some other issue that I need to look at?
Thanks for your help-
Slick Steve
1999 Valkyrie Interstate,
2003 1800 VTX
Cliff
Manchester, NH
« Reply #1 on: June 10, 2010, 02:48:02 PM »
sure sounds like battery (how old is it?),,, check connections at battery first though.
VRCC # 29680
big turkey
« Reply #2 on: June 10, 2010, 02:54:22 PM »
Before you go  and lay down a hundred or more for a new battery.
Check one thing.
Take the Driver's seat off and check those battery bolts.
I have found on mine the blots will loosen up after a while and I don't know why.
If They are not tight , even the least bit loose.
Clean Contacts, Tighten and retry the starter.
If they were loose to begin with, charge it and then see if it cranks.
This day in time it pays to save a little money.
I had another Valk Owner tell me this when I told him my battery bolts were loose for no obvious
reason.
Free Advice if it does not work I will give your money back.
Big Al
Slick
Jupiter, Florida
« Reply #3 on: June 10, 2010, 03:18:08 PM »
I don't know the age of the battery, as I bought the bike a year ago with 23,000 miles.
I will take off the seat (if I can figure that out) and give the connections a good cleaning and tightening-
Thanks again folks-
2003 1800 VTX
big turkey
« Reply #4 on: June 10, 2010, 03:43:36 PM »
Seat is the easiest thing you can remove on that bike besides the Fuel Cap.
Ignition key lock under the front of your seat, insert key turn clockwise and you will hear it realese.
Nothing to it.
If it is  standard or Tourer even the better, no radio in the way.
I think a 10 mm open end wrench and turn them clockwise to tighten, if they need cleaning it
will be obvious.
Charge it slow if you have to..
2 amp or less.
Battery tender in your future is a good idea.
Prevents low batteries and stops or slows sulfation.
Big AL
Cliff
Manchester, NH
« Reply #5 on: June 10, 2010, 03:43:51 PM »
Thanks again folks-
on the seat side of the opening just under and in front of the the front of the seat is a key hole, use your ignition key there to release the front of the seat, you may have to press down hard on the front of the seat while turning the key.  Once the front is released just lift and pull forward and it's off!     Big AL beat me to the punch!!!  Smiley  cooldude
« Last Edit: June 10, 2010, 03:46:16 PM by Cliff » Logged
VRCC # 29680
Slick
Jupiter, Florida
« Reply #6 on: June 10, 2010, 06:05:14 PM »
Can I use jumper cables from my car to jump the bike? Any special instructions?
2003 1800 VTX
Cliff
Manchester, NH
« Reply #7 on: June 10, 2010, 07:10:14 PM »
As long as you can make the connection with out shorting the pos to frame.  I have done the car jump with no problem.
OK to jump from a non running auto. Don't have the car running could get a spike.
« Last Edit: June 10, 2010, 07:36:31 PM by Cliff » Logged
VRCC # 29680
Ben
Abilene TX
« Reply #8 on: June 10, 2010, 07:21:01 PM »
Slick, a battery tender is $20. at walmart..batteries last 3 X longer.
Alternator is not running against a low battery so it should last longer as well
GOOD LUCK.  cooldude Shocked
Mr.BubblesVRCCDS0008
« Reply #9 on: June 10, 2010, 07:29:47 PM »
franco6
Houston, TX
« Reply #10 on: June 10, 2010, 09:37:27 PM »
chek kill switch, off - on a few times as well as side ways Smiley
Enjoy the ride!
Slick
Jupiter, Florida
« Reply #11 on: June 11, 2010, 02:03:08 PM »
Got home from work today and took the seat off (your right simple) connections were very loose and tightened them up- still no start. Hooked up some jumpers to my car and boom first try, fired like a champ.
Guess it's time to buy a battery charger and see if she'll hold a charge- or else go buy a new battery-
2003 1800 VTX
Slick
Jupiter, Florida
« Reply #12 on: June 11, 2010, 02:13:05 PM »
Ran her about ten minutes (low fuel remember) and shut her down three times, she fired right back up-
Thanks Big Al & Cliff, as well as the other members that chimed in to help a brother out-
2003 1800 VTX
Cliff
Manchester, NH
« Reply #13 on: June 12, 2010, 05:14:25 AM »
Don't mention it, always willing to help someone in need!  Glad this worked out not costing your any hard earned cash!  Of course Big AL's instructions were much clearer  Smiley  cooldude
« Last Edit: June 12, 2010, 05:15:58 AM by Cliff » Logged
VRCC # 29680
