January 31, 2026, 09:01:58 AM *
Author Topic: Ugly brown spot  (Read 1932 times)
boppa
Rome, Ga
« on: June 11, 2010, 11:27:25 AM »
Hope someone can help. Recently a brown stain has appeared at the tube going to the #6 clyinder at its base where the acorn nuts are. Any advice as to what it might be and how to stop it?
                                     Tia,
                                            Boppa
eric in md
« Reply #1 on: June 11, 2010, 11:34:03 AM »
sure can change your orings in there easy to do .. intake orings .. you need 6 of them
1FAST6
Sanford, NC
« Reply #2 on: June 11, 2010, 11:41:07 AM »
$12.50 for the set from here.  Great people to deal with.  I got my quick-disconnect from them.  These are much cheaper than Honda parts and higher quality material.
http://home.everestkc.net/richyrich/index.html
Baloo
Rimouski, Canada
« Reply #3 on: June 11, 2010, 12:08:27 PM »
Yep, mine is doing exactly the same. Did not have a chance to replace the o rings yet. Thanks for the link, 1fast6, it will come in handy!  cooldude
Never ride any faster than your guardian angel can fly...
« Reply #4 on: June 11, 2010, 03:03:31 PM »
its gasket tack used to hold the o-ring in the manifold during assembly, that is melting from engine heat. check the tightness of the acorn nuts 6.5 ftlbs., or 1/4 to 1/2 turn more than they are now.
use very short wrench, less chance to over tight
« Last Edit: June 12, 2010, 01:55:50 PM by CA ExhaustCoatings » Logged
« Reply #5 on: June 12, 2010, 08:27:49 AM »
It certainly sounds like dried fuel, and since you stated it was around cylinder #6, I'd take a look at the vacuum line and petcock..
