November 19, 2025, 12:04:29 AM
poping
Topic: poping (Read 3820 times)
scissorman
poping
March 19, 2009, 09:46:47 AM »
what will cause a slight poping when i back off the throttle. thanks
bassin
Arkansas
Re: poping
March 19, 2009, 11:32:52 AM »
Well mine started taht and I found a vacumn hose had craked and was allowing air flow . Check the hoses connected to the carbs. Hope that helps that was my trouble.
Psychotic Bovine
New Haven, Indianner
Re: poping
March 19, 2009, 02:15:16 PM »
I had found a missing header bolt. that was allowing a very tiny amount of air into the exhaust and would pop on decel.
"I aim to misbehave."
Big Rig
Woolwich NJ
Re: poping
March 19, 2009, 05:51:24 PM »
What year is your bike??? Had the same thing this past August....Vacuum line had a hole in it....temp fix was electrical tape over the leak. Popping stopped right away...replaced with 5/32 vac lines from auto zone about $5.
Let us know how you make out.
John U.
Southern Delaware
Re: poping
March 19, 2009, 06:07:13 PM »
Check out the screw clamps on the boots that attach the intake tubes to the carbs. There are two per. I just checked mine and two of them loosened up in 1 riding season.
Intake tube O-rings get flattened out and leak too. Any vacume leak can cause that.
Zorba
Ride the Dragon
What's the "Pope" doing in your Bike?
March 19, 2009, 07:49:39 PM »
Could not pass that one up, sorry Bro!
scissorman
Re: poping
Reply #6 on:
March 21, 2009, 05:24:41 AM »
problem solved ,vac line . thanks
=> InZane XXV
