Valk1520
« on: June 13, 2010, 05:10:21 PM » |
I've seen a posting like this that helped someone so I thought I would try it. I'm in the Holland area and looking for a good, honest Mechanic to work on my IS when needed. The shops seem to be too busy and very expensive. I'm willing to help with repairs but being a jack of all trades, master of none, I need guidance. Let me know if you're willing or know someone that can. Thanks, as always, for all the help everyone offers!
Joe Hummer
Arnold, MO
« Reply #1 on: June 13, 2010, 05:22:56 PM » |
Too bad you aren't closer to St. Louis...but, you would have to wait until the u-joint comes in for my buddy's Standard...It should be here this week. Won't take too long to put it back together.
What type of work do you need to have done??
Joe
1999 Valkyrie Interstate You pay for the whole bike, why not use it Jerry Motorman Palladino
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #2 on: June 13, 2010, 05:51:36 PM » |
I'm in Grand Rapids, what are you looking for?
RTaz
Oscoda, Michigan
« Reply #3 on: June 14, 2010, 04:48:18 AM » |
...long time Michigan Valkyrie guru is Fuzzy ...he is from Lake just west of Clare...shoot him an email you won't regret it....larrance@core.com
 RTaz
loafer
« Reply #4 on: June 14, 2010, 05:11:20 AM » |
Check out stadtcycle.com. Dan Stadt is a fine mechanic and has done work on my Valkyrie as well as my Gold wing. He is respected and fair, and has always done a good job for my. In fact, I intend to call him today to have some things done on my Valkyrie
F7daved
« Reply #5 on: June 14, 2010, 01:12:59 PM » |
Do A Search On Fuzzy Just Saved Me $600.00 On repairing my tourer. Trust me you wont go wrong.
Oyeaa
« Reply #6 on: June 14, 2010, 02:03:34 PM » |
I can lend a hand if you need, I am in St. Joseph MI. I have done a bunch of work on my Intestate and have nothing but good things to say about the mechanic.
Valk1520
« Reply #7 on: June 14, 2010, 06:38:22 PM » |
I wondered if I need to sync my carbs. My IS has a little over 51000 miles on her and this year the exhaust seems to have a smell of gas which I didn't notice last year, my gas mileage went from 38 mpg (average) to around 34. Over the winter I put on an Audiovox cruise and installed a K&N air filter which I just replaced tonight with a stock filter and checked all vacuum lines which look good. Carbs are untouched (stock), the only mod I've done to the bike was cut the piggies off a couple years ago and since then I noticed my headers are bluing. Maybe my right wrist is a little stronger than years before or I'm worried about nothing, that's why I was looking for someone who can work with me on my bike that won't charge an arm and a leg just to put it on the lift. Thanks for all the replies so far!
Oyeaa
« Reply #8 on: June 15, 2010, 05:40:04 PM » |
Carburetor Synchronization is a good idea, along with setting the pilot screws. Based on what you have done it is relatively simple process that you can do yourself no need to pay a mechanic. Send me an email with contact info and I can give you a hand if you need it.
valk99 NOSPAM @sbcglobal.net remove NOSPAM
RTaz
Oscoda, Michigan
« Reply #9 on: June 16, 2010, 08:09:33 AM » |
Have you changed spark plugs? Have you ever adjusted your valves? Have you ever had a carb sync.? Have you ever checked your fuel petcock? Have you ever run sea foam through fuel system? If you say no to any of the above.....call fuzzy
 RTaz
Valk1520
« Reply #10 on: June 16, 2010, 07:03:01 PM » |
I did plugs last year and Sea Foam every winter. I just replaced K&N air filter with a stock filter and put a whole can of Sea Foam into a 1/4 tank, ran several miles and let it sit for a day then filled tank. The IS seems to be running smoother and more responsive. I haven't run it long enough to check mileage, hopefully this weekend. I haven't touch the valves or carbs yet, that's something I'm not able to do on my own that's why I was hoping for someone to work on it with me or for me. Is Fuzz in this area?
RTaz
Oscoda, Michigan
« Reply #11 on: June 17, 2010, 05:02:20 AM » |
Fuzzy is over in Lake Mi. just west of Clare ...he will travel but also has a garage to work out of....
 RTaz
