November 21, 2025, 09:17:26 AM *
Author Topic: Spline lube - THANK YOU!!!  (Read 2554 times)
TGViper
« on: June 13, 2010, 08:18:21 PM »
Just a big word of thanks for all the great help on this board.  Just finished the spline lube and o-ring replacement.  Had 40k miles, bought with 37K so am going through everything to make sure I know what I got.
Gears looked great but moly was just about gone so good thing I got to it.  Brakes are done now (front and back).
Thanks again to all my fellow Valk Brothers and sisters.
fat6man
Crystal City, Missouri
« Reply #1 on: June 13, 2010, 09:13:18 PM »
A few other thing to check with your mileage... Don't forget to flush your brake and clutch fluids with DOT-4. Might also check your vacuum and fuel lines for wear. Vac. line size is 3.5 mm (5/32nd inch) and fuel line size is 8 mm (5/16th inch). Don't forget the Air Filter.
Enjoy your new Gal. and ride safe!!!     cooldude
Mr.BubblesVRCCDS0008
« Reply #2 on: June 14, 2010, 03:14:50 AM »
Also you might think about the final drive fluid. I change mine about every 15K.
« Reply #3 on: June 14, 2010, 11:05:52 AM »
For everyone's information:  Service manual's stated replacement interval is 24,000 miles (although nothing wrong with 15K).
« Reply #4 on: June 14, 2010, 12:05:53 PM »
I do mine about ever time  I have the rear tire off. The oil is cheap and the final drive is not, so I just do it for peace of mind. And my mind needs all the peace it can get these days. cooldude
« Reply #5 on: June 14, 2010, 07:18:10 PM »
Yea, a quart does about 3-4 changes, cheap insurance for me too Mr. B...
Hay  Cool
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #6 on: June 15, 2010, 07:16:28 AM »
Hay  Cool
And it's SOOOO easy.  5 min.
Jabba
JetDriver
Columbus, OH
« Reply #7 on: June 15, 2010, 02:50:37 PM »
Is there any reason to think that final drive fluid would go bad in a sealed container over the years?  I'm thinking of how once you open a brake fluid container, you use what you need and throw out the rest, as it attracts and absorbs moisture, even in a tightly closed container.  I've got some final drive fluid in a tightly capped plastic bottle (the bottle it came in) that's 7 or 8 years old now.  Still ok to use that??
MP
North Dakota
« Reply #8 on: June 15, 2010, 03:19:20 PM »
Probably.  But...... a new bottle for a few bucks, is good for a few years.  Why take the chance?
MP
"Ridin' with Cycho"
Larry
Northeastern BC, Canada
« Reply #9 on: June 15, 2010, 04:38:07 PM »
Brake fluid absorbs moisture and you don't want that in your brake lines. I don't think you have to worry about left over final drive oil as the system is not under pressure like brake fluid is in a closed system.
Snowflake
Dakota...The North Side
« Reply #10 on: June 15, 2010, 09:05:42 PM »
Final drive get filled to bottom of hole while bike is on kickstand or while bike is straight up?
SnowFlake
fat6man
« Reply #11 on: June 15, 2010, 10:39:27 PM »
I fill mine with bike straight up on bike lift - I believe full capacity to be approx. 5.1 oz.
Wildman
« Reply #12 on: June 16, 2010, 12:31:54 PM »
TGViper
Don't forget to change the anti-freeze with a silicate free long life solution.
I hear it's the most over-looked maintenance item on water cooled bikes.
JetDriver
Columbus, OH
« Reply #13 on: June 17, 2010, 06:12:19 AM »
Honda Service Manual says, " place bike on level service and support it upright."  Although they might have been able to be a little more clear, my vote is with fat6man, and fill it while bike is straight up.
