November 21, 2025, 08:22:08 AM *
Author Topic: solid Billet Valve stems - opinions?  (Read 1591 times)
Cliff
Manchester, NH
« on: June 14, 2010, 07:34:57 AM »
Anybody have experience with these?  Good, bad or indifferent??
http://www.motorcycleanchor.com/tire_valves/index.htm
VRCC # 29680
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: June 14, 2010, 07:46:27 AM »
You have to grind down the retaining tab (for the plastic stem holder) on the wheel if you want to use this on the Valk.  It only takes a minute of so, just don't sneeze  while holding the grinder Grin.
I have one on the rear and it appears to be fine, easy to fill and check with a 90 accutire guage. It was done after the last rear tire was changed due to a flat.
Tried to break the front bead with c-clamps but was unsuccessful so will wait until that tire gets swapped before swapping it out.
1FAST6
Sanford, NC
« Reply #2 on: June 14, 2010, 08:18:22 AM »
I took mine off and replaced with Patchboy type.  I did not grind the tabs and mounted them facing the left side.  Very difficult to access.  Love the new ones!
« Reply #3 on: June 14, 2010, 09:18:05 AM »
I have them on the Valk. Rear has the "T" cut off for a right side fit. Front faces left as I haven't cut the "T" off yet. Much easier access and you don't have to hold the stem while checking pressure.
1FAST6
Sanford, NC
« Reply #4 on: June 14, 2010, 09:29:54 AM »
This is what I replaced them with.  $2.50 ea and $2.63 to ship.
http://automotive-hardware.com/1-piece-1-78-chrome-90-inner-mount-tire-valve-p-269.html
« Reply #5 on: June 14, 2010, 03:02:16 PM »
That is what I have also......
