January 31, 2026, 10:28:51 AM *
Author Topic: Plugs are fouling  (Read 1981 times)
Kelly230
« on: June 17, 2010, 02:43:34 PM »
I have a '98 Tourer and the plugs are fouling.  Carbs have been rebuilt (it was running rich at sea level, and really rich at 4700 feet where I live).  It does have 6 into 6 exhaust.  Runs strong, but the fouled plugs concern me.  We talked about rejetting it, but I've heard this is rarely done.
shortleg
maryland
« Reply #1 on: June 17, 2010, 02:52:11 PM »
  First thing check your air cleaner.
Found one at Inzane that had a nest
built by mice in it. I know it sounds strange
  The reason I say this is you talk like it is all
 of the plugs.
               Shortleg[Dave]
Kelly230
« Reply #2 on: June 17, 2010, 03:10:38 PM »
Actually, 4 are bad, one is a bit dirty, and the one near the vacuum line is clean.
shortleg
maryland
« Reply #3 on: June 17, 2010, 06:24:49 PM »
 Look at your plug wires and the cyclinder number
is on it.
  Sounds to me like you my have a carb problem.
Time to go in. You can find help here and our repair
manual.
               Shortleg[Dave]
« Reply #4 on: June 18, 2010, 04:05:21 AM »
The vacuum line ?? There are actually 3 ,, but,, there are vacuum fittings on each intake.. So the clean plug near the 'vacuum line' may be caused by a defective vacuum line[cracked/split].. Where are the pilots set ?? At altitude they can set tighter[1/2 turn].. What needles are you using and where are they set?? You may try setting them tighter also if they are aftermarkets..
« Reply #5 on: June 19, 2010, 10:42:34 AM »
Are you the original owner?
Could be the previous owner has installed a lot of aftermarket parts in the carburetors which you are unaware.
A complete cataloging of whats there now would be important in trying to get to the bottom of the fouling problem.
How is the condition of the motor? Have you performed a compression test. This is the one test you should do especially in view of the fouling plugs.
