January 31, 2026, 10:29:05 AM *
Author Topic: Stupid.....Stupid......Stupid!!!!!!!!!  (Read 2603 times)
Slammer
Lafayette,La.
« on: June 17, 2010, 08:30:51 PM »
Took a ride last nite-first in 3 weeks-rode about 5 miles started missing -no power-pull over turn off-let sit-startup runs good-take off-1.5 miles same crap-oh no dyna 3000 is dead-limp home swap out dyna with stock-takes about 10 minutes-startup runs great-kick dirt & cuss dyna-turn off go to bed-jump on tonite startup take off-3 miles same thing-sit on side of rode pissed-brain storm-CHECK VENT TUBE STUPID-MR. Dirt Dobber had done his thing-sorry about what I said about you last nite Mr.Dynatech
Slammer
« Reply #1 on: June 18, 2010, 03:53:40 AM »
A dobber in your vent tube,, hummm.. I thought the vacuum break[ T]  in the line would have prevented something like that.. Anyway, good tip, and glad its back running..
Slammer
Lafayette,La.
« Reply #2 on: June 18, 2010, 05:02:03 AM »
when I put the engine back in last year(another story) in my infinite wisdom I decided that the tee wasn't needed. DUH!!! guess what gets put back on today.
Pete
« Reply #3 on: June 18, 2010, 06:01:51 AM »
The TEE is not there for wasp prevention, it is there to prevent a vaccum from forming when water spatter from the road enters the bottom of the drain.
« Reply #4 on: June 18, 2010, 06:40:31 AM »
Yep, but, thats why that little T shaped critter is called a vacuum break.. Speaking of little critters, I guess we'll now have to make all these little red covers with warning flags to stick on anything that could have something crawl up inside them, kinda like we do for aircraft..
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #5 on: June 18, 2010, 06:45:33 AM »
I had a Dyna 3000 go tits up on mne once.  I carry a spare now.  Plus... they replaced it inder warranty, and probably should NOT have since I bought it used.  AND they upgraded me to the newer version.
I keep mine in a ziplock now.
Jabba
Jack
Benton, Arkansas
« Reply #6 on: June 18, 2010, 12:19:49 PM »
I can just see you fussing, Slammer!  Grin
Slammer
Lafayette,La.
« Reply #7 on: June 18, 2010, 02:50:16 PM »
because I know there are no more Dynas being made and no repairs being done. I sure like the sound of that engine at about 8500 rpm. I know it's not really making power up there but it sure sounds good!!!!!!
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #8 on: June 18, 2010, 02:55:18 PM »
Had dobbers build a nest in a fan shroud on one of my bikes a few years ago. I didn't find it until the wiring harness caught fire  Cry
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
