January 31, 2026, 10:29:01 AM *
Author Topic: trunk guard rail question  (Read 1823 times)
alph
Eau Claire, WI.
« on: June 18, 2010, 11:34:24 AM »
when installing the trunk guard rail, do you have to take the shell out?  my buddy has a set that are not honda line, and they didn't come with any instructions.  pictures would be great!!
thanks,
al.
Cattman
Franklin, IN
« Reply #1 on: June 18, 2010, 11:37:20 AM »
Yes, shell must come out.
alph
Eau Claire, WI.
« Reply #2 on: June 18, 2010, 12:19:43 PM »
thanks cattman!!  hopefully will be seeing you at inzane?!
Oyeaa
« Reply #3 on: June 18, 2010, 02:15:38 PM »
I know you are not installing the Honda Line trunk guard rail, but I have instructions for installing these in pdf format that may be useful in the trunk tear down.  Send me your email and I will send them to you.
You may find these pictures useful in getting both sides placed equally as there is not a really good reference point to measure from in deciding where to drill the holes.
OverdueBill
Elkmont, Alabama
« Reply #4 on: June 18, 2010, 10:03:32 PM »
If they are like the ones I installed, be prepared for a struggle.  They seem like they are too wide but they will fit.  If you help your buddy, it will go a lot better.  About a million screws around the top edge.
tank_post142
south florida
« Reply #5 on: June 19, 2010, 07:02:25 AM »
if they are the ebay ones, i had to remove close to one inch of pipe from each side so they would fit. used a pipe cutter and took it off where they meet in the center, redrilled the holes for the coupler, sealed the fresh cuts and holes with clear fingernail polish before mounting.
I got a rock Sad
VRCCDS0246
