January 31, 2026, 10:28:54 AM *
Author Topic: How to modify lift adapter for Rivco center stand?  (Read 2248 times)
quexpress
Montreal, Québec, Canada
« on: June 19, 2010, 07:13:01 PM »
Hi!
A fellow rider with a Rivco center stand on his Valk, asked me if I knew how to modify a lift adapter such as this one, to be used on a Valk with a Rivco center stand.
http://www.valkyrieriders.com/shoptalk/New_Lift/home.html
I told him that I didn't know but, if it has been done, somebody here would know how.
Any insight would be very appreciated!  Cool
Normand
I still have a full deck.
I just shuffle slower ...
Joe Hummer
Arnold, MO
« Reply #1 on: June 19, 2010, 07:20:01 PM »
from my experiences with my Rivco center stand bracket, I would cut off the upright pieces off that bracket.  Leave the cross piece.  That will rest on the rivco bracket.
I use 2x2s under my bike.  two long ones to run under the motor then a shorter one crosswise to hit the rivco bracket.
Joe
1999 Valkyrie Interstate
quexpress
« Reply #2 on: June 19, 2010, 08:39:01 PM »
Is this with, or without a lift adapter?
Thanks Joe!
Joe Hummer
Arnold, MO
« Reply #3 on: June 20, 2010, 08:51:17 AM »
I do not have a lift adapter.  my 2x2s are my lift adapter.
quexpress
« Reply #4 on: June 20, 2010, 09:21:30 AM »
I hear you! I have a lift adapter but only use it if I'm doing major work on my Valk ... and that has not happened for a while.
Usually I just place the jack arms under the engine. This permits the front end of the Valk to be raised.
If I need to raise the whole bike (i.e.: including the rear wheel), I simply place a short piece of board on the jack to catch the rear portion of the engine ... and then lift it. Following a mishap, I now avoid heavy work on the bike in this position because it is not very solid. I've done that in the past, and of course, the bike slid backwards on the jack. Fortunately I was able to prevent it from going down!  uglystupid2
Thanks!  cooldude
