January 31, 2026, 11:57:13 AM
Best way to remove saddlebag reflectors?
Topic: Best way to remove saddlebag reflectors? (Read 1620 times)
BOZ
June 25, 2010, 03:02:39 AM »
What's the best way to remove the reflectors on the I/S saddlebags? I'm replacing them with lights and would appreciate knowing the best method of removing the reflectors. Thanks in advance.
Cliff
Manchester, NH
Re: Best way to remove saddlebag reflectors?
June 25, 2010, 04:26:31 AM »
Not sure how they are mounted, if mounted using peel and stick stuff you can usually work a piece of monofilament fishing line behind whatever is mounted with it and with a sawing motion work the line behind it until you have it off and then clean up the sticky residue. Of course on a warm day this would be easier.
VRCC # 29680
shortleg
maryland
June 25, 2010, 06:09:55 AM »
Hair dryer and then fishing line under each of them.
Then Goo Gone or 3M remover.
Shortleg[Dave]
