November 21, 2025, 10:10:18 AM
What type of grease
Topic: What type of grease (Read 1627 times)
PhredValk
Edmonton, Alberta, Canada
What type of grease
June 28, 2010, 08:57:53 PM »
What type of grease to use on control levers?
Fred.
VRCCDS0237
redflash
Southern New Hampshire
Re: What type of grease
June 29, 2010, 03:07:50 AM »
I use red synthetic marine grease and I still get an occasional creaking and not smooth application on very humid days that drives me nuts. Brake fluid was changed this spring, so that isn't it.
Cliff
Manchester, NH
June 29, 2010, 03:49:16 AM »
Service manual calls for silicone grease.
VRCC # 29680
redflash
June 29, 2010, 04:03:57 AM »
I'll give that a whirl on the plunger contact point. I'm pretty sure the pivot points don't care as long as they're greased with sumpin.
Cliff
Manchester, NH
June 29, 2010, 04:54:16 AM »
Quote from: redflash on June 29, 2010, 04:03:57 AM
I use Guard dog Moly grease, so far smooth and no creaking/squeaking.
VRCC # 29680
PhredValk
June 29, 2010, 05:17:03 AM »
Thanks. I installed the Kury adjustable GL1800 levers and still have to push the brake forward with a finger to get the brake lights to cancell.
Fred.
VRCCDS0237
Rio Wil
Reply #6 on:
June 29, 2010, 08:53:09 AM »
Quote from: Fred on June 29, 2010, 05:17:03 AM
Fred.
I have the same levers and had to build up the area of the lever that contacts the microswitch with about 6 layers of aluminum tape.
Cliff
Manchester, NH
Reply #7 on:
June 29, 2010, 09:41:52 AM »
Fred.
Is it possible the spring inside the master cylinder needs to be replaced?
VRCC # 29680
=> InZane XXV
