January 31, 2026, 11:57:12 AM *
Author Topic: Valkyrie Rim Stains  (Read 2630 times)
Rusty Hook
« on: June 29, 2010, 06:31:12 PM »
 Is the rims on a 1997 Valkyrie coated with a clear coat ? I cleaned my tires with a strong cleaner and now my rims are stained. What could I use to polish them back out ?
N8171S
Marlboro, Mass
« Reply #1 on: June 29, 2010, 06:37:29 PM »
Valks made for US were not clear coated.  Try 600 wet sand and then a mag wheel polish.
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #2 on: June 29, 2010, 06:41:16 PM »
Some were clear coated, depends on the year. Someone will chime in I'm sure.
Dress for the slide, not the ride. ATGATT
VRCC #2505
Brad
Reno, Nevada
« Reply #3 on: June 29, 2010, 06:58:46 PM »
I believe that clear coat on standard rims did not start until 2001.  Those stains should come out with a little polish.
Oldswimr
NE North Carolina
« Reply #4 on: June 30, 2010, 09:12:35 AM »
Mothers.. cooldude
"Yes, it's fast, no you can't ride it.."
Daniel Meyer
The State of confusion.
« Reply #5 on: June 30, 2010, 11:10:35 AM »
Correct. Standards, 2001-up came with polished/clearcoated wheels and rear drive pumpkin.
CUAgain,
Daniel Meyer
« Reply #6 on: June 30, 2010, 12:32:31 PM »
Yep...aluminum polish and a special grease........its called L-bow grease   cooldude
mine looked very bad when I first got the bike.......now people ask if I had them professionally done..........
houstone
Can't get enough...
Santa Fe, TX
« Reply #7 on: June 30, 2010, 05:35:38 PM »
Sweet lookin' Valk!  What is the trailer hitch, if I might ask?
« Reply #8 on: June 30, 2010, 05:52:47 PM »
Thanks...its a hitchdoc
sheets
Jct Rte 299 & 96, Calif.
« Reply #9 on: June 30, 2010, 07:15:47 PM »
Been there - did that. Once. Ten years ago. Took an hour or more of L-bow grease on each side of each wheel to rectify the error of my ways. Was a painful lesson. Don't use the chemical cleaner crap unless you have a charged hose standing by to immediately wash it off.  Yrmv,
Daniel Meyer
« Reply #10 on: July 01, 2010, 06:32:58 AM »
There are protective coatings available in certian places on the road that keep pretty much anything from getting to the shine on the wheels (including light)
(pic)
CUAgain,
Daniel Meyer
Rusty Hook
« Reply #11 on: July 02, 2010, 12:12:48 PM »
 Thanks for all the information on removing the stains. I went to WalMart and bought some Turtle Wax Chrome Polish and some Mothers Chrome Polish with the Mothers Power Ball and extension. That was the ticket !!!  I started off with the Turtle Wax , it cut thru the stains quick. Then polished it with the Mothers Chrome polish . My rims look like Chrome now . The turtle wax has more grit in it to cut the stains,and the Mothers has a finer grit to polish. I wish I had taken a before & after picture of my rims now. The Mothers Power Ball let me get up into the rim behind the disc brakes too.
« Reply #12 on: July 02, 2010, 12:24:55 PM »
Mothers makes an aluminum polish too that works greaton aluminum
