July 17, 2025, 04:45:39 PM *
Author Topic: HD Airshocks for a Valk  (Read 1181 times)
Heinno
« on: June 30, 2010, 03:49:11 PM »
Hi
I want to install airshocks from HD Roadking on my Valk. Will they fit or would you need to do some major mods? (bushings, spacers etc)
If anybody had done it, please let me know it works
Hein
« Reply #1 on: June 30, 2010, 04:13:00 PM »
do a search, I believe this was done by somebody or discussed last yr
Heinno
« Reply #2 on: June 30, 2010, 05:04:45 PM »
Hi
Thanks, I did a seach and it all talks about how they ride etc - I am looking for installation directions - can anybody assist or direct me on were I can find the posts, thanks
Hein
« Reply #3 on: June 30, 2010, 05:51:52 PM »
http://valkyrie-owners.com/SMFORUM/index.php?topic=5948.0
NJF6Cowboy
« Reply #4 on: June 30, 2010, 07:43:55 PM »
I gave them a try on my Interstate last year. Bought a set of Harley takeoffs brand new showa air shocks on Ebay. Modified bushing ends at  a buddies machine shop.
Spoke with Harley head mechanic was told 2 up he would run no more than 25lbs. At 25lbs the shocks constantly bottomed out. After trying increased pressures finally set at 75lbs psi. Rode real nice for a while and I liked them but they started to leak fluid and finally air pressure would not hold. So I took them off went back to stock shocks and Gary's bushings.
If you look at the Road Kings the air shock is almost vertical and on our valks the shocks ride at at angle. The angle is what, I think, did in the air  Showa air shocks.
Hope this helps you.
