paul
« on: July 01, 2010, 01:13:17 PM » |
Just looking to see if anyone has mount ideas/pics. for a volt meter on the I/S.. Thanks...There is an overhauled alt. off a 94 wing in the neighborhood for 60.00 if any one needs one...
shortleg
« Reply #1 on: July 01, 2010, 01:51:54 PM » |
Try mounting it on the pods,on the black part under the vent. Shortleg[Dave]
paul
« Reply #2 on: July 01, 2010, 02:50:09 PM » |
I was thinking that to shortleg...what about up on the dash? more if a quick glance than look down??
Thunderbolt
« Reply #3 on: July 01, 2010, 05:14:02 PM » |
Just a cheapo from Harbor Freight.
PapaHotel
« Reply #4 on: July 01, 2010, 08:33:03 PM » |
I had one of the Kury led models. The faceplate came off and I had exposed LEDs/ So I called Kury and asked for a replacement. They said they do not sell them. I decided to drill holes in my panel above the right speaker. I have a small arc of holes that match the LEDs. I can see the lights just fine.I did make adjustments for the day/night sensor on the unit by adding a white LED behind the panel
Cattman
« Reply #6 on: July 02, 2010, 08:31:31 AM » |
Same here mines in the right pod face. Very bright readable LED's
Mr.BubblesVRCCDS0008
« Reply #7 on: July 02, 2010, 09:03:13 AM » |
Mounted my on top of the triple tree on the right hand (brake side). Not right in sight but easy to see at a quick glance. I then moved it up to the bottom side of the tach insert. Very easy to see but I had to put two layers of tape under it to get it high enough to clear the lip of the inset.
« Reply #8 on: July 02, 2010, 09:12:55 AM » |
I like mine small simple and easy to see its the light to the lower left of the tach. Its a signal dynamics and it changes color according to charge.
« Last Edit: July 04, 2010, 05:45:37 AM by Robert »
valk2001
There is nothing like riding a Fat Girl....
Darlington, SC
« Reply #9 on: July 05, 2010, 05:13:01 AM » |
I have a Stinger digital voltmeter mounted on the LH speaker cover that is bright enough to read in daylight (blue display). Note that the gauge is reading 11.7 volts because bike is not running with lights on. Also the camera flash washed out the display.
paul
« Reply #11 on: July 11, 2010, 07:24:42 AM » |
Thanks for the Ideas//replies... appriciate it..
Kingbee
VRCC# 576
Northern Illinois
« Reply #12 on: July 11, 2010, 07:52:39 AM » |
« Reply #13 on: July 11, 2010, 03:16:57 PM » |
here is where I put mine in the right pod It also lets me know the fog lite is on
