November 21, 2025, 12:08:21 PM *
Author Topic: Intake Manifold O Ring Replacement  (Read 2263 times)
Loki
Katy, Texas
« on: July 02, 2010, 07:21:55 AM »
K, so I've noticed I'm getting some oil leakage, not a lot, but out of about 3 of my intake manifolds.
I've ordered the O rings and am just going to replace all 6.  Doesn't look like it's going to be a difficult job but just want to run it by the collective to make sure I know about any gotcha's I might encounter in the process.
Any advice?
Thanks!
Marc.
Marc
'00 Valkyrie Interstate - Loki
'85 V65 Magna - Big Bird
eric in md
« Reply #1 on: July 02, 2010, 07:29:44 AM »
piece of cake you can do it..
« Reply #2 on: July 02, 2010, 08:11:47 AM »
You'll want to notice that all the parts are indexed so they have a right way to fit and also a wrong way.
Loki
Katy, Texas
« Reply #3 on: July 02, 2010, 08:19:39 AM »
Yeah, I think I'll do it one at a time, replace the O ring and put it back together before I go on to the next one.
Marc
NITRO
Eau Claire, WI
« Reply #4 on: July 02, 2010, 10:35:49 AM »
Be careful pulling the vacuumm lines off the intakes. I ended up pulling one off from under the air box and ended up having to remove the tank and air box to put it back in.
That said, I recently replaced them on Alph's IS and had the job done in 30 mins with no problems.
When in doubt, ride.
Loki
Katy, Texas
« Reply #5 on: July 02, 2010, 10:45:50 AM »
Someone told me, and I don't remember who that I don't even have to completely remove them.  Just loosen up the rubber grommets from the top, un bolt from the bottom and slip in the O rings.  (of course, after removing the old o ring.)
Thanks for the advice all, I'll let you know how it goes.  Just waiting on getting the rings in from Cheap Cycle parts.
Marc
Marc
Jack
Benton, Arkansas
« Reply #6 on: July 02, 2010, 10:53:33 AM »
Loki, the hardest part was making sure the o-rings stayed in place when I re-positioned the intakes.  uglystupid2
1FAST6
Sanford, NC
« Reply #7 on: July 02, 2010, 11:51:38 AM »
Be careful not to overtighten the bolts.  6.5 ft/lbs.
Loki
Katy, Texas
« Reply #8 on: July 07, 2010, 05:57:58 AM »
Good advice all.  Still haven't recieved the rings.  Waiting on the order to be shipped.  SLOOOOOW.
Marc
« Reply #9 on: July 07, 2010, 07:19:00 AM »
Some people hate taking off the tank, so this might sound stupid...
I had the tank off... unbolted the airbox... unbolted all the intake runners from the heads...
now the airbox with the six runners was just free-floating around... it was so easy to
take each runner out, no mashing or stressing with the tubes that go back to the airbox...
-Mike "I don't hate taking the pipes off either, but then I've never had a stud break"
Warlock
Magnolia, Ms
« Reply #10 on: July 07, 2010, 09:19:46 AM »
Any advice?
Thanks!
Marc.
Do it the easy way. Remove the six intake bolts on one side. This will let you be able to lift it just a little to put the o-rings in. Once finished with that side do the other side. Taking all the bolts aloose makes it easy.
David
