January 31, 2026, 11:58:35 AM *
Author Topic: tech tip funnel anyone?  (Read 2191 times)
« on: July 02, 2010, 09:05:51 AM »
The best funnel I have found is a empty bottle of water wetter with the bottom cut out. It screws right into the oil hole and its like hitting the easy button. cooldude
« Reply #1 on: July 02, 2010, 09:58:22 AM »
looks handy.  I now buy the 5qt jug of Mobile 1.  I dont really trust removing one qt and hoping I have 4 left....so I got a measured on/off funnel.....I pour in one qt, it has a hose that goes in the fill hole then you turn on the flow..........do it 4 times and save the rest....someday Ill get a free oil change out of it......well free in that the 5qt jug costs about the same as 4 1qt bottles so after 4 rounds of changing I should end up with a sort of free gallon of oil.........
« Reply #2 on: July 02, 2010, 11:03:44 AM »
Speaking of oil, how is the un-refined oil situation in the pan-handle ??
« Reply #3 on: July 02, 2010, 11:43:35 AM »
Dont get me started on that.........two and half months and we ALMOST have a super skimmer operating in the Gulf of Mexico.  Its gonna be bad until our wee little ones right now grow up to be adults
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #4 on: July 03, 2010, 05:18:03 AM »
Screws right into the hole...! Wow, that there was designed for the Valkyrie, no drips, no mess cooldude
  How much does that funnel cost?
« Reply #5 on: July 03, 2010, 06:09:01 AM »
Heres the catch the funnel is free the water wetter is about 9.00  Grin
ricoman
Sarasota, FL
« Reply #6 on: July 04, 2010, 08:04:27 AM »
no thread hi-jack intended, but how is the WaterWetter doing for you?
added to existing 50/50 mix or diluted with water as they suggest?
« Reply #7 on: July 04, 2010, 11:15:01 AM »
I really like the water wetter and it performs as it says it will. I only keep a 10 percent solution of anti freeze and a whole bottle of wetter. If you live up north you can use a 50/50 mix with no problems but being in S Fla its hot and with the lower concentration of anti freeze it keeps the bike additionally cooler. Grin
fuzzy2bucks
« Reply #8 on: July 04, 2010, 12:00:35 PM »
"....so I got a measured on/off funnel.....I pour in one qt, it has a hose that goes in the fill hole then you turn on the flow.........."
So ChrisJ CMA ... What is this special funnel your using and where can I get one?  cooldude
« Reply #9 on: July 04, 2010, 01:37:15 PM »
I got it at wally world (near the oil) made by Hoppy and its essentially the tube you use to fill a tranny, the one that screws onto a bottle of fluid and has a turn spout.  well its just attached to a 1 Qt tub with measured marks on it.......simple thing
