January 31, 2026, 11:58:40 AM
fuel leak
Topic: fuel leak (Read 1680 times)
mnvalkrider
fuel leak
July 02, 2010, 09:14:59 AM »
We just bought a 800 drifter for my wife to ride and it came with a leak at the petcock. i changing the oring and the leak was still there. i noticed that the bolt holding the petcock on threaded into the gas tank with no cap on the inside, thats where the leak is. it drips around the bolt. has anyone had luck using like permatex 2 or something like that? any suggestion appreciated . mnrider
Re: fuel leak
July 02, 2010, 09:22:14 AM »
I think I would drain the tank, remove the petcock and make sure theres no faulty parts, maybe another 0-ring clean everthing and put it back together correctly first.......then if you cant stop the leak, try gunky stuff to seal it, at least that way you know you arent covering up a problem
mnvalkrider
Re: fuel leak
July 02, 2010, 09:47:30 AM »
Thanks for the reply Chris. I have been through that process once. maybe should try it again. I just think its unusual for the bolts to thread into the tank with no baffle inside to keep the fuel away from the threaded bolt. It looks like the oring is doing the job but the fuel is following the thread down. I just thought that maybe someone had put to long a bolt in and popped the inside caps off or something. The tank has been painted. mnrider30547
Re: fuel leak
July 02, 2010, 10:41:14 AM »
Get some small 'O'-rings for the bolts and use them wherever two surfaces meet.
mnvalkrider
Re: fuel leak
July 02, 2010, 02:13:44 PM »
it turns out what i needed was plastic washers on the bolts, and no metal flat washer, which is what was on it. simple fix for a smelly problem! thanks for the input again. glad i didn't use the permatex. sometimes it is to easy to go for the quick fix. ride on! mnvalkrider.
