January 31, 2026, 11:58:31 AM *
Author Topic: 97 Tour, I have noticed an odd sound coming from the motor/ where is the clutc  (Read 2039 times)
dennis_obryan1965@msn.com
« on: July 02, 2010, 03:35:38 PM »
It sounds like a squeaking, chirping  sound coming from the inside of motor . It comes and goes and It  stops when I pull the clutch in.
Where is the clutch push rod and how do I lube it?
« Last Edit: July 02, 2010, 03:44:52 PM by dennis_obryan1965@msn.com » Logged
fstsix
« Reply #1 on: July 02, 2010, 05:19:51 PM »
Look up under the motor at the back of the clutch, the slave cylinder is right there, pull it out and put some grease on the push rod, not that hard.
matt
Derry New Hampshire
« Reply #2 on: July 02, 2010, 05:31:02 PM »
grease on push rod  I have never heard of that    how often should that be done
« Reply #3 on: July 02, 2010, 06:05:45 PM »
How often should you grease the push rod?? Only when it tells you to..
« Reply #4 on: July 03, 2010, 10:46:40 AM »
dennis, it sounds like more of the same variety of typical sounds from a leaky (bad) vacuum hose on the smog control hosing system.
It does come and go with no apparent regularity.
A de-smog will stop it.  So will changing out the offending hose.
« Reply #5 on: July 04, 2010, 03:49:42 AM »
Is the push rod and the lifter rod in the clutch slave cylinder the same thing ?
blkvlk777
« Reply #6 on: July 04, 2010, 05:06:52 PM »
X2 with the cracked vacuum line theory.  My 99 did that about 8 years ago - change the vacuum lines,  rerouted them slightly and never had another problem.   Feel under the #3 or #4 vacuum line to see if it is split.
good luck.
« Reply #7 on: July 06, 2010, 04:37:20 AM »
Thanks all for the advice.
