January 31, 2026, 11:57:14 AM
Seafoam in oil
Topic: Seafoam in oil (Read 2467 times)
Phil Owen
Seafoam in oil
July 05, 2010, 08:46:55 AM »
Has anyone ever tried adding Seafoam to the oil? If so how much did you use?
Re: Seafoam in oil
July 05, 2010, 09:09:39 AM »
I think that is for more of putting it in right before you change the oil. Thins it out to aid in cleaning and draining. Kerosene works to I hear.
Re: Seafoam in oil
July 05, 2010, 10:42:20 AM »
The can says it can be used in the lube oi, but, my question is, why would anyone wish to do so?? It works well as a fuel system cleaner and stabilizer, but, just my opinion, I wouldn't use it in the oil..
fuzzy2bucks
Re: Seafoam in oil
July 05, 2010, 11:48:46 AM »
The only way I could see using Sea Foam in engine oil is if the engine was very dirty and it should be put in only for a 50 mile ride or so.
flash2002
Montreal, Que
Re: Seafoam in oil
July 05, 2010, 03:56:37 PM »
I think that sea foam is great in the gas, but I'm not sure I would put it in my oil. It might work on car engines, but on a bike they have a wet clutch, not sure....
Pete
Re: Seafoam in oil
July 05, 2010, 04:18:12 PM »
I do not recommend this but if you feel it is necessary.
Then not more than 1 to 1.5 ounces of Seafoam per quart of oil.
DO NOT run the engine under heavy load or high RPMs nor longer than necessary,
As you have thinned your oil with an agent that may also foam and may limit your oil pumps ability to pump effectively.
Change the oil and filter SOON after.
Ferris Leets
Catskill Mountains, N.Y.
Re: Seafoam in oil
Reply #6 on:
July 05, 2010, 06:37:48 PM »
I have been using Marvel Mystery Oil for years in all of my vehicles. In the gas and oil. Works for me.
fuzzy2bucks
Re: Seafoam in oil
Reply #7 on:
July 05, 2010, 10:03:28 PM »
Used Marvel Mystery oil in my Honda Civic after Amzoil messed up the manual shifter. Used it in my Gas and Oil.
Phil Owen
Re: Seafoam in oil
Reply #8 on:
July 06, 2010, 10:21:49 PM »
I guess I'll nix that idea! Thanks for the info.
