January 31, 2026, 11:57:09 AM
led for rear & wiring in on interstate
Topic: led for rear & wiring in on interstate (Read 1713 times)
Doc X
July 05, 2010, 09:00:13 AM »
It is a two stage LED so I guess there will be three wires . Where and how can I get to the rear lights wiring on the interstate, I mean the easy way. Will take all suggestions and yes I have the electrical ability of a dead light bulb. The how means how to do it!!!!
Doc X
tank_post142
south florida
Re: led for rear & wiring in on interstate
July 05, 2010, 10:34:14 AM »
wiring for the rear lights is under the right side cover. follow the harness coming out of your rear fender under the seat right into the set of connectors covered with a clear(yellowed) sleeve.
solid blue = rt turn
orange = lt turn
brown = license light/running lights
green w/yellow stripe = brake light
Last Edit: July 05, 2010, 10:38:52 AM by tank_post142
I got a rock
VRCCDS0246
Kingbee
VRCC# 576
Northern Illinois
July 05, 2010, 11:44:31 AM »
Remove one of your tail lights, one screw in the trunk does it. Access to what you need is right there. There is also a hole in the bottom of the trunk to feed your wires out to your LED.
Back off flasher
powered by
Aeva
1999 Interstate
2000 Interstate
2004 Rune
tank_post142
south florida
July 05, 2010, 12:57:40 PM »
oops! for some reason i thought he was installing leds in the bags. KB is right on if your installing a a light bar on the trunk. 2 screws hold each light in.
I got a rock
VRCCDS0246
