January 31, 2026, 11:29:46 PM *
Author Topic: Another tire question....what causes tire cupping?  (Read 3535 times)
mark@umt.com
his and hers at Key West, FL
Toronto, ON
« on: July 07, 2010, 09:15:26 PM »
I know this is probably a pretty newbie question...but what causes tire cupping?
Ultimate Motorcycle Tours...it's where the adventure begins...http://www.ultimatemotorcycletours.com
Airetime
Anacortes, WA
« Reply #1 on: July 07, 2010, 09:37:25 PM »
 Roll Eyes OK, take a little trip down Chet's pages, I think that you can get lost with all the articles on our Valks but here on this link you will find your answer...
http://www.rattlebars.com/valkfaq/tirewear/index.html
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #2 on: July 08, 2010, 05:30:22 AM »
Typically, low air pressure. Check often. Also check your manufacturers website for the recommended pressure, it may not be the same as you owners manual, I know Avons are different.
Dress for the slide, not the ride. ATGATT
VRCC #2505
« Reply #3 on: July 08, 2010, 06:37:10 AM »
When I used to run bike tires, I always carried 50# in the rear to help slow down the cupping........
Car tire, never ever seemed to have that probleme.
Jay
« Reply #4 on: July 08, 2010, 07:52:40 AM »
I know pressure seems to be the popular reason for cupping.  However, I ran 40psi front and 42psi rear for years, Avons and E3's and always had some cupping.  The last front was an E3, ran 40psi as always but had Dyna beads in it, and after 13,000+ miles it wore evenly, no cupping.  I am inclined to think the beads kept a constant balance thus eliminating the cupping.
mark@umt.com
Toronto, ON
« Reply #5 on: July 08, 2010, 08:13:34 AM »
Actually, when I'm on the road I actually check my tire pressure daily as I found it can change significantly depending upon air temperature and altitude.  I did keep 40# in the front and rear originally when I put my Avons on, but ended up picking it up to 45# front and rear.
I'm thinking of going with the Metzler 880's now...I had them on my C-90 and was quite pleased with the performance and longevity of the product.
Thanks for all the responses!  Smiley
Mark
TJ
Lake Placid , Fl.
« Reply #6 on: July 08, 2010, 09:02:34 AM »
There are only two thing that can cause cupping...
1  Bad shocks
2 Out of balance tires
« Reply #7 on: July 08, 2010, 09:07:43 AM »
Cupping can be caused and promoted by any number of things, air pressure not withstanding.
The tread design, angles of the tread pattern with relation to the road while riding, siping and the angle of the siping to mention a few.
Plus riding style, types of roads, crowns and rutting, use of brakes and style of braking, harshness of turning.
Rubber compounds, contact patch profile,
You get the idea.
There are many, many factors contributing to that particular thing, air pressure being only one.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #8 on: July 08, 2010, 11:34:29 AM »
Tire pressure. 1-3 pounds above specs fixed my coupling  problem.
mark@umt.com
Toronto, ON
« Reply #9 on: July 27, 2010, 01:24:09 PM »
Hey all,
Just got my metzler ME880's and LOOOOOOOVE them!  They grip to the road really well...even in severe rain which I ran into this past Saturday.
I greatly appreciate all the comments on this topic....but finally went with the choice that made sense to me based on my riding style and comfort level.  Smiley
Mark
Farther
Quimper Peninsula, WA
« Reply #10 on: July 27, 2010, 02:43:02 PM »
My front Metzler is showing cupping after 12k miles.  I keep around 43-45 pounds in it and check frequently.
~Farther
mark@umt.com
Toronto, ON
« Reply #11 on: July 27, 2010, 02:47:38 PM »
12K miles I can deal with...mine were cupping at 8.5K miles....that's not very good...and I check them daily when I'm on a tour?!?
I think I'll stick with Metzler instead of Avons from now on.
Thanks for the PSI.  Smiley
Farther
« Reply #12 on: July 27, 2010, 02:58:34 PM »
I think that low tire pressure only accellerates cupping in a tire that is out of balance.  Unless some super tire comes along I will be running Metzlers on both ends of my bike for the forseeable future.  If I hadn't gotten a slow leak in the rear I think I would have gotten about 14k out of it.  A new 180/70-16 Metzler in stock size from Jake Wilson cost $143.00 including overnight shipping.
~Farther
mark@umt.com
Toronto, ON
« Reply #13 on: July 27, 2010, 03:04:34 PM »
WOW!  That's really good!  I paid $182 including shipping from motorcycle superstore.  What is his web address?  Does he ship across the US?
Farther
« Reply #14 on: July 27, 2010, 04:50:28 PM »
http://www.jakewilson.com/home.do?gclid=CL28gsryjKMCFSISagodRGhiTw
http://www.couponshack.com/stores/show/5730/Jake-Wilson?r=aw&k=jake%20wilson%20coupon%20code
~Farther
