July 17, 2025, 05:51:11 PM *
Author Topic: Speedo/Tach Bezel w/ Visor Sought  (Read 1276 times)
Divot
Retired - VRCC #30489
Boise, Idaho
« on: July 08, 2010, 04:13:44 PM »
In previous post someone mentioned they found some plastic chrome bezels w/ visor that fit the Valks speedometer and tachometer.  Supposedly, these are about $5 each.  I've checked at several truck stops, visited the local semi-truck dealer and still can't seem to find something that will work.
Does anyone who has found these have the brand name and/or part number to help me track down a set?  Thanks in advance.
2000 GL1500C - Black
1980 Honda 185 XL
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #1 on: July 08, 2010, 04:24:02 PM »
I bought mine from a local truck-stop chrome shop, about $4.00. They are excactly the same shape size and dimension of the Kuryakyn, which cost more. I will look for more info. for you, as far as the brand, if I can find it. I know several others here have used the same ones as myself, maybe they will chime in. If you have no luck, try posting on the Florida board, everyone there uses them.
Flat6Valk
Blacklick, Ohio
« Reply #2 on: July 09, 2010, 09:42:34 AM »
try valkyrie bling and more.  they used to sell some visors for the valk
R J MILES
« Reply #3 on: July 09, 2010, 05:23:52 PM »
Bought at local truckstop. Brand name on package is CG. Part # 68393. Cr. plastic gauge cover w/visor for Peterbilt or Freightliner pyrometer. Put mine on with thin line of silicone sealer. Cut small slot at bottom to drain any water out. Masking tape to hold in place while the silicone sealer dries. FUZZY
« Reply #4 on: July 09, 2010, 05:45:50 PM »
Thx, we got 2 truck stops in the area. 1- 4 miles from work. If I find some I'll get a few.
