March 17, 2026, 10:43:16 PM *
Author Topic: So, all I have to do is  (Read 1105 times)
iba1990
Rocky Mountain High !
Thornton, Colorado
« on: July 10, 2010, 06:58:55 AM »
Good morning to all. So, all I have to do to install an Avon Cobra 200 tire is remove the "NUT CAGES" from the rear fender of my 97 Valk Standard. I had a 99 Valk Interstate & installed a car tire on the rear. Everytime I got off the bike I would smell burning rubber. I always thought in the back of my mind that I was going to have a BLOWOUT because the tire was rubbing on some part of the bike. That would not be good if I were on an IBA ride or any other ride. I have had two blowouts on motorcycles in 55 years of riding them. And, I was always a long ways from nowhere. Not a pleasant experience as some of you may know. Anyway, if I remove the nut cages I should be able to installed the 200 Cobra...right? Seems simple enough. Thanks for the info. Ride safe. tommy t IBA 1990
Challenger
« Reply #1 on: July 10, 2010, 07:43:16 AM »
I had a 200 Metz on my STD until a couple weeks ago (ran over something sharp) Nut cage mod only and not a mark on the tire or a smell of rubber burning.
« Reply #2 on: July 10, 2010, 11:06:27 AM »
Once my nuts came loose, and I heard my fender rattling... I'm sure I didn't tighten properly
when I had stuff apart or something.
I was glad my nuts were still in their cages.  cooldude
¿spoom
WI
« Reply #3 on: July 10, 2010, 11:52:37 AM »
That may or may not do it. It seems Honda had a success rate of maybe 10% when it came to centering the fender over the rear tire  Wink
A lot of folks (myself included) had to go to carriage bolts from the inside out on one side after removing the cages. In my case it was a bad move because I didn't like the handling as much and I went back to a 180 after that one 200 wore out.
wdvalk
Katy Texas
« Reply #4 on: July 10, 2010, 02:05:08 PM »
Glad this thread popped up,I too am considering the 200 metzler,I would like to here more opinions from yall that have run it,how many have not done the nuts in a cage mod ,pros? cons?
