November 21, 2025, 01:28:03 PM *
Author Topic: Throttle sleeve  (Read 2245 times)
Farther
Quimper Peninsula, WA
« on: July 11, 2010, 01:26:55 PM »
I'm not sure what it's called but I need to replace the inner plastic rotating sleeve on the throttle side of the handlebars.  I somehow broke off the chrome cap with the threaded mounting still in the cap.  I can't find the part on the microfiche.  I assume I will need a new grip, chrome cap and sleeve.  Any help on getting the parts numbers and how to replace this part is appreciated.
~Farther
Daniel Meyer
The State of confusion.
« Reply #1 on: July 11, 2010, 01:44:02 PM »
You could also just replace your stock grips with some aftermarket ones (yeah, can't spell kuriakiankiyakn).
Anyway, they don't use the threaded piece.
CUAgain,
Daniel Meyer
Farther
« Reply #2 on: July 11, 2010, 01:52:42 PM »
Thats a very good idea.  It would simplify the installation and I could go with the Kuryakyn throttle assist too.
~Farther
« Reply #3 on: July 11, 2010, 02:04:26 PM »
07     GRIP, R.              53145-MM8-000  001           $26.81
08     GRIP, R.              53145-MM8-000  001            $26.81
10     CAP, GRIP END     53167-MM8-000  001            $5.66
I like the small diameter OEM grips better than any aftermarket grips I know of... I replaced
the chrome grips that came on my bike with OEMs...
-Mike  Wink
Farther
« Reply #4 on: July 11, 2010, 02:09:02 PM »
Thanks, that is just what I was looking for.  Where did you find that schematic?
~Farther
« Reply #5 on: July 11, 2010, 02:29:30 PM »
All the on-line OEM parts sellers have it... I habitually go to Honda Direct Line... Here's the link for 1997
Valkyries, all the others are there too...
http://www.hdlparts.com/fiche_select2.asp?category=Motorcycles&make=Honda&year=1997&fveh=3476
Daniel Meyer
« Reply #6 on: July 11, 2010, 03:18:14 PM »
You'll need the sleeve too for the OEM...it doesn't come with the grip.
CUAgain,
Daniel Meyer
Farther
« Reply #7 on: July 11, 2010, 06:26:29 PM »
It's hard to tell from the schematic but it show that parts ref. number 07 & 08 have the same parts number and price.  I would imagine that I would get two grips if I just ordered by what is shown.  Anybody have any insight on this?
~Farther
Valkpilot
What does the data say?
Corinth, Texas
« Reply #8 on: July 11, 2010, 06:47:13 PM »
08 GRIP, R.
53145-MM8-000  (replaces 53165-MM8-000)  001 $31.92 $26.81
Last time I ordered a sleeve, you had to get the grip. Apparently they come as a package and you can't order the throttle sleeve by itself.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #9 on: July 11, 2010, 08:11:28 PM »
Same here... I mean, I wanted the grips, so that's what I ordered. Was glad to find that the
right grip had the sleeve on it...
vanagon40
Greenwood, IN
« Reply #10 on: July 12, 2010, 06:55:10 AM »
To the extent there is any doubt, part # 53145-MM8-000 is the plastic throttle tube with the OEM grip glued to the tube.
Farther, I would assume you could reuse the original cap by removing the broken tube end from the cap, but I also suppose that for $5.66 it might not be worth spending a whole lot of time on it.
The problem with adding aftermarket grips or something else using the existing broken grip is that you need to make sure you keep the grip glue on the OUTSIDE of the throttle tube.  If the end is broken off, if will be difficult to keep the glue from getting in between the throttle tube and the handle bar, prohibiting the throttle tube from rotating freely.  (Don't ask me how I know).)
Farther
« Reply #11 on: July 12, 2010, 08:40:40 AM »
Going with the OEM grip was by far the most economical option and I do preferr the slimmer OEM grips over the aftermarket grips.  Order placed today with Direct Line Parts.
~Farther
