January 31, 2026, 08:20:25 PM *
Author Topic: Water temp indicator?  (Read 2176 times)
Ferris Leets
Catskill Mountains, N.Y.
« on: July 14, 2010, 08:48:21 AM »
A little while back someone was posting about water temp problem??'.  A comment was made that the temp light on the Valk does not come on with the ignition as the oil light does.  Mine does.  They both come on at startup.  Or did I read the original post wrong?
trantony
Keep the shinny side up and rubber side down!
Baton Rouge, La.
« Reply #1 on: July 14, 2010, 11:07:15 AM »
Check again! Unless mine is burned out Embarrassed, I only get a side stand and oil light on startup.
Leon
VRCC #1860
1997 Valkyrie Tourer
2005 ST1300
2016 Polaris Slingshot SL LE
Ferris Leets
« Reply #2 on: July 14, 2010, 11:59:11 AM »
Side Stand Light?  Which one is that?
Red Diamond
Beaumont, Texas
« Reply #3 on: July 14, 2010, 02:33:45 PM »
It's in the Tac bezel.
Fathertime
Washington County, New York
« Reply #4 on: July 15, 2010, 08:08:26 AM »
 Ferris,
  On the Tach face are three Idiot lights.  From left to right they are High coolant warning, oil pressure and side stand down.  What I was asking was if the left most light, the high temperature warning light, came on with just the ignition on.
« Reply #5 on: July 15, 2010, 08:20:16 AM »
Unless it is bipassed, then it wont come on.
Ferris Leets
« Reply #6 on: July 17, 2010, 10:30:56 PM »
IS no lights in the tach, temp light definitly  comes on with the key.
Bone
« Reply #7 on: July 18, 2010, 04:43:09 AM »
The temp light comes on when the coolant is over the specified temperature.(Owners Manual) 98 Tourer
Mine does not come on with the ignition.
Ferris Leets
« Reply #8 on: July 18, 2010, 11:29:30 AM »
The IS does not have a kickstand light?
