January 31, 2026, 01:40:30 PM *
Author Topic: SeaFoam question  (Read 2534 times)
boss hoss bill
« on: July 15, 2010, 01:29:08 PM »
My Valk is a little hesitant Sad when I first take off cold in the morning , after letting it run for about a minute,by then the choke is off, (I usually keep it on for about 30 seconds .)
It smooths out quick, 10-15 seconds so I figured a little Seafoam would be good for it.
The question is how much?  crazy2
The can says 1 oz per gallon, but I've read posts where people dump in the whole can. I was figuring about 5-6 ozs, as I am on reserve now and will be filling it up soon adding about 31/2 gallons or four.
Bill
« Reply #1 on: July 15, 2010, 02:22:46 PM »
I say dump it in. I just put some carb cleaner in last night in my 1/2 tank. The bottle said treats 21 gal.  crazy2
« Reply #2 on: July 15, 2010, 02:45:18 PM »
The stuff isn't cheap.  What I do is a bit stronger than one-ounce-per-gal dose with about a half-to-third tank left when I plan to take a 25-40 minute freeway blast (to blow it out).  Run it to reserve, then fill up.  This way you can get several treatments per can of Seafoam.  I mean, if my bike was running badly, I might use a whole can.  But my bikes run great, so I give then each a maintenance dose every so often. YMMV
« Reply #3 on: July 15, 2010, 03:46:38 PM »
It really doesn't sound that bad and I doubt that sea foam will make a difference but it cant hurt. Use the whole can in fact you could put 2 cans in with no ill effects.
« Reply #4 on: July 16, 2010, 04:18:34 AM »
MHO on seafoam
http://www.valkyrieforum.com/bbs/index.php/topic,17174.0.html
« Reply #5 on: July 16, 2010, 05:51:32 AM »
I like Techron better that Seafoam!
Lately I've been using B-12 with no ill-effects.
« Reply #6 on: July 16, 2010, 09:23:55 AM »
CA good articles
Ricky were not talking about your personal vitamin needs  2funny
« Reply #7 on: July 16, 2010, 09:37:42 AM »
CA good articles
LOL   2funny
Thanks R, at least one person reads my post  Sad
« Last Edit: July 16, 2010, 02:05:30 PM by CA ExhaustCoatings » Logged
Pete
« Reply #8 on: July 16, 2010, 10:27:03 AM »
I prefer Berrymans B12 or Techron, both seem to work equally well.
But if a bike has sat and the gas has dried out in the carbs (several times) leaving a hard residue, nothing but strong carb cleaner, a brush and elbow grease will remove it. Same for jets.
1fastbob
South Central Kansas
« Reply #9 on: July 17, 2010, 08:34:50 AM »
Boy I sure hate to agree with CA, but I have had zero success with Seafoam.  I am real sorry I purchased a gallon of that over priced mineral oil crap.  Techron, BG 44K and B-12 all seem to be much better.
« Last Edit: July 17, 2010, 08:43:18 AM by 1fastbob » Logged
I'm on somebody's list! BFD!
