July 18, 2025, 03:48:41 AM *
Author Topic: Must do some PM to my Motorcycle...  (Read 1930 times)
Raverez
No good deed goes unpunished
Central New York State
« on: July 19, 2010, 05:44:07 PM »
So, I have some questions. I have a '99 Interstate.
1.  I need to fix the fork seals. Right one's leaking for about a year.
Is it necessary to remove the fairing?
2. starting to get a swish-swish noise in the rear when going slow( about 20-30mph). Also  some squealing. I'm thinking the shaft drive needs to be lubed.
3. Just bought a Big Red jack for the bike. where can I get the adapter? Followed some of the posts on here about a permanent one.
4. Any mechanics in the central NY area that can help? I want to do the work, but don't want to screw it all up.
Thanks for any help you can give.
Raul.
« Reply #1 on: July 19, 2010, 06:02:42 PM »
search "valkyrie adapter" on ebay... a couple of the "stay on bike" ones are there now for about $29...
Michvalk
Remus, Mi
« Reply #2 on: July 19, 2010, 06:19:27 PM »
In order of listing
1.No you do not HAVE to remove it. Just pull the tire, and drop the forks. Lift high
2.I'm thinkin wheel bearings, Most likely the left side rear. Check the other stuff when it's apart.
3.There are some websites that they are available on, but, I don't know which ones. Look at Ebay. Maybe someone else will chime in.
4.I'm not sure if New York has a state board or not. Look on the home page under regional boards.
Finally use the search archive function for any info that you need for the parts you are working on. I can't believe that you could find any topic that does not have many threads on. If you have a specific question for anything, post on the board,and someone has fixed or helped fix the thing your are asking about. You  WILL get an answer fairly quick. Good luck
Ferris Leets
Catskill Mountains, N.Y.
« Reply #3 on: July 19, 2010, 06:48:11 PM »
Where in NY?
Raverez
« Reply #4 on: July 19, 2010, 06:51:44 PM »
Syracuse,
X Ring
VRCC #27389, VRCCDS #204
« Reply #5 on: July 19, 2010, 07:18:24 PM »
Do a search on bearings and you'll see a lot of opinions including mine.  Get your bearings at a bearing house and buy top tier bearings like SKF.  You get what what you pay for.  Puchase according to the cheapest price and you'll be replacing them again pretty soon.  Better yet go to Shoptalk and do the 5204 Bearing Mod.  http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
Marty
« Reply #6 on: July 20, 2010, 07:37:41 AM »
The swish might be rear brake pads worn out. Check that before going any deeper in the rear end. And yes the forks come out without removing the fairing.
Raverez
« Reply #7 on: July 20, 2010, 07:41:25 AM »
The swishing noise stops when when in gear and I pull the clutch in. But I do have the rear pads to replace also.
Raverez
« Reply #8 on: July 20, 2010, 09:33:45 AM »
Ok. A few more questions.
What kind and how much fork oil do I put into each fork?
Should I change the springs?
What do I use to lube the rear wheel gears?
Thanks for the help.
Raul
« Reply #9 on: July 20, 2010, 09:57:09 AM »
Some kind of good 10wt fork oil... Here's a link to the details:  http://www.valkyrieforum.com/bbs/index.php/topic,14829.msg124449.html#msg124449
Progressive springs are a big improvement over OEM.
There's a lot of information on that you can search out of the tech board... here's one thread:
   http://www.valkyrieforum.com/bbs/index.php/topic,8241.0.html
You need a service manual... Dag has one online at valkyrienorway...   http://www.valkyrienorway.com/1520manual/valkyriegl1500.zip
Raverez
« Reply #10 on: July 24, 2010, 07:47:03 AM »
Getting ready to get the parts for the forks.
From what I see on HDL parts page,  I need:
# 21Seal set
# 8 Back up ring
# 9 Guide Bushing
# 10 Slider Bushing.
Fork oil 10wt
Should I change the springs? Bike has just over 49k miles.
« Reply #11 on: July 24, 2010, 09:52:08 PM »
The "squealing" might just be an accumulation of brake dust.  Try washing your Valk first and see if it goes away.
« Reply #12 on: July 25, 2010, 04:13:45 PM »
Hi Raul
I am the new  NY State Rep. since Dino has dissapeared for many years now
When it was time to do the fork seals I rode over to the DalaiLama's but he is in Connecticut
He said that when you do the seals put the new ones in the freezer first so they go in real easy. You can go on Dag's website and the instructions for fork seal change are in the honda manual he has online  You can make the special tool with pvc pipe, cut it lengthwise and use duct tape to hold the 2 pieces together
The closest folks to you would be BigD and the Inspector over towards Buffalo
MikePeace says hi by the way
« Reply #13 on: July 25, 2010, 06:57:55 PM »
Make sure you put the seals in the Correct way, they will leak if you happen to put them in backwards.  (Don't ask)
